The default status configuration in the following template is invalid: PTC.SCA.SCO.KepserverBasedPhysicalAssetThingTemplate. Fix the template in ThingWorx Composer to create this type of equipment.
1:
2:
1 is the case and 2 is mine. How can I fix this problem?
Check this KB article for the possible solution - https://www.ptc.com/en/support/article/CS314948
