facing this error
required solution
tried restarting TomCat and KepWare still of no use
Hi Shakti, where are you seeing this error? Would it be possible for you to attach that full log here?
BTW, does this also mean your ThingWorx is not starting up? Or are you able to access the ThingWorx Composer?
Hi Shakti
Try running services:
I had a similar issue with the Kepware Server Thing.
I just got rid of this error on the kepware thing by disabling IE ESC in windows and rebooting.
