I have two thing templates "Plant Thing Template" & "Department Thing Template". While creation of "Department Thing Template", I have inherited the "Plant Thing Template" as base thing template, to inherit & store certain properties.
Now, I want to get the list of implemented things from "Plant Thing Template" separately and "Department Thing Template" separately. The issue is "GetImplementingThings" of "Plant Thing Template" is returning things implemented by both "Plant Thing Template" & "Department Thing Template"
Can someone please suggest a solution
Run GetImplementingThings on both and use the InfoTable Functions Intersect to get the difference
else you can tag each entity upon creation and do a searchbytag
