Hi Team,
We are trying to implement Anomaly Detection using Thingwatcher(Licensed Thingworx platform and Thingwatcher) . We are getting Anomaly Alert from Thingwatcher whenever Anomaly is detected.But the problem we are facing is it is taking five minutes to reset Alert which is very high.
In our case We have set “Outbound Anomaly rate” to 5 seconds. And we are sending the values of temperature at the rate of 4 values per second. The values will be like 27,28,26,29. If the temperature got increased for more than 30 for a minute, we are getting alert as expected with in few seconds . But for Alert reset it taking more than 5 mins.
I am attaching screenshot of alertHistoryStream . All the Alerts of type AnamolyAlert had anomaly for less than a minute .But you can see for AlertReset it is taking more than 5 minutes.
Is there any way to improve as Alert and Alert Reset are equally important, please suggest .
Hi Lalith Kumar
Could you please follow the below thread in case it helps otherwise we can reach out to our R&D team.
Thing watcher anomaly detection alert reset
