I have a setup of thingworx 7.4 where i am able to generate generate prediction models from analytics builder and publish them to analytics manager for real time data scoring using thingpredictor agent ,my question is can i do realtime data scoring without using thingpredictor only in thingworx analytics .
Kind Regards ,
Amar
Hi Amar
To perform real time scoring you do need to use ThingPredictor.
The Analytics Server in itself can obviously perform scoring (see How to score new data with ThingWorx Analytics ?), however because of the need to load the new data in the Analytics Server and perform the scoring, which requires manual intervention, this is not real time.
Hope this helps
Kind regards
Christophe
Hi Amar
Hope this helps
Kind regards
Christophe
