Hello all,
I have some questions regarding the data mapping process in the Thingworx-Analytics-Manager for creating an Analysis event.
Here are some basic information about the predicitve model:
- I want to predict the Time to Failure (TTF) and have followed this instruction: https://community.ptc.com/t5/IoT-Tech-Tips/Predicting-Time-To-Failure-with-ThingWorx-Analytics/m-p/579897#M1095
- In my model I used the function "useGoalHistory" becaus this showed better results for my usecase
- the data set is a time series data set
- ThingWorx Version 9.0
My questions:
1. In the Input Data Shape my goal variable appears ("TTF"). How can this happen? I thought that I have to map the goal variable in the Result mapping? Is this maybe caused by the fact that I am using the goal history?
2. One input parameter changed the datytype. During uploading the dataset on ThingWorx Analytics for training the model, the parameter was described as "Integer". Now when I want to map this parameter to the data of a Thing the parameter suddenly has the data type "Number". My problem now: Now I can't map the parameter to the data in the Thing because the datatypes don't match. How can I solve this problem?
Thank you already in advance.
Best regards
David
Hi @DF_10027356
Indeed you have the goal in the input datashape because you sue use goal history, this make the goal a input for the next prediction.
Regarding the change of data type, it might be good to open a case to Technical Support for further investigation.
As a test, you can try to manually change the data type in the datashape directly.
If you select your Analysis Model and select View > Datashapes, you will see the name of the datashape used.
You can then find them in Composer and change the type from Number to Integer.
Hope this helps
Regards
Christophe
