Hi, there!
Documentation only shows a partial list of available entity types and also a partial list of the available characteristic collection types.
Where can I find the full list of both, available entity types and available characteristic collection types?
Nahuel
Hi @nahuel ,
There is a small mail icon on that documentation page that you can use to send feedback for that page.
I have used that icon many times in the past and it gets processed for sure, it's just not instantaneous.
I think your suggestion is a good one, and I suggest to send that feedback to complete that list.
In the mean time, I needed this in the past as well, and computed the following list, I tried my best to format it since it was based on my Javascript code:
case "Projects":
case "Things" (valid for "Wiki", "Blog", "ValueStream", "Stream", "DataTable", "IndustrialConnection", "IntegrationConnector")
case "ThingTemplates":
case "ThingShapes":
case "DataShapes":
case "ModelTags":
case "Networks":
case "Mashups" (valid for "Master", "MashupTemplate", "Gadget")
case "Dashboards":
case "Menus":
case "MediaEntities":
case "StyleDefinitions":
case "StyleThemes":
case "StateDefinitions":
case "DataTags":
case "PersistenceProviders":
case "Groups":
case "Users":
case "Organizations":
case "ApplicationKeys":
case "DirectoryServices":
case "Authenticators":
case "LocalizationTables":
case "Resources":
case "Subsystems":
Hi nahuel
I find below content, hope it is helpful for you:
Below is a sample code snippet that gets a list of all entity types, iterates over one entity type and then iterates through all entities in that type checking for the isSystemObject aspect's value is set to true:
var result = Resources["SearchFunctions"].SpotlightSearch({
maxItems: 1000000 ,
types: { items: ["Thing",
"ThingShape",
"ThingTemplate",
"DataShape",
"Network",
"ModelTagVocabulary",
"Mashup",
"Menu",
"MediaEntity",
"StyleDefinition",
"StateDefinition",
"DataTagVocabulary",
"Group",
"User",
"ApplicationKey",
"Resource",
"Organization",
"Dashboard"
aspects: { isSystemObject: true },
maxSearchItems: 1000000
for each (row in result.rows) {
// do something with each row
Best Wishes!
Teresa
Hi Teresa, thanks for your reply.
But what I'm looking for are the same kind of tables that are found on the documentation link I added in my first post.
Above Entity Collection Types table you can find the following message "The entity types listed below is only a partial list of the available entity types." and above Characteristic Collection table you can find a similar message. Where can I find a both complete lists?
PD: I've checked API documentation but I couldn't get any out of it. I find it unfriendly.
Hi @nahuel ,
case "Projects":
case "ThingShapes":
case "DataShapes":
case "ModelTags":
case "Networks":
case "Dashboards":
case "Menus":
case "StyleThemes":
case "DataTags":
case "Groups":
case "Users":
case "Resources":
case "Subsystems":
