ThingWorx Flow Error [FLOW-API-01] after regenerating self-signed certificate
GabrielAzevedo
Hi everyone,
I am running ThingWorx Flow 9.3.10 and I’m hitting a wall trying to fix an expired self-signed certificate.
The Issue: My self-signed certificate for Flow expired, so I needed to regenerate it. I followed the official guide here: CreateSelfSignedCertificate.html
I generated the new files, placed them in the SSL directory, and restarted the services. However, Flow is now failing to connect.
Symptoms:
  1. Redirect Loop: When I try to open the ThingWorx Flow app, it automatically redirects me back to the ThingWorx Composer.
  2. Validation Error: When I run ValidateFlowSetup in the WorkflowSubsystem, I get:
    [FLOW-API-01] - Failed to connect to Flow: Internal Server Error
  3. Log Error: The flow-exchange module logs show this error, which suggests a trust issue:
    {"module":"flow-exchange","timestamp":"...","level":"error","message":"unauthorized access"}
It seems like the internal services aren't accepting the new certificate I generated. Has anyone experienced this? Is there an extra step missing in the documentation to update the internal TrustStore or Keystore?
Any advice would be appreciated.
Thanks!
Hello @GabrielAzevedo,
Please provide the following information:
  • OS and version
  • ThingWorx Platform version
  • Port used for accessing ThingWorx Platform and Flow
  • Whether ThingWorx Platform is accessible via the nginx (Flow) port
  • Whether Flow is installed on the same machine as ThingWorx Platform
  • Whether Flow was working as expected before the self-signed certificate update
  • Please also ensure:
    • The **Issued To** name on the certificate must match the hostname of the ThingWorx Flow server to avoid certificate-related errors
    • `server_name` is correctly set in `<nginx_home>\conf\conf.d\vhost-flow.conf`
    • `extra.crt` and `orchestration.crt` files match
Abhi
