ThingWorx Installer fails
- 3 replies
- 1941 views
- Translate All
I am trying to install TWX9.3 with the installer and I am using the Linux version with PostgreSQL (MED-61111-CD-093_SP2_ThingWorx-Foundation-Installer-postgresql-linux-9-3-2). The OS that I am using is CentOs8 64bits. I have the right version of java (11) which is installed and setup in the path and I have also setup the PostgreSQL path. When i run the installer, it gets all the way to 96% and there it freezes at the step: "ThingWorx Foundation for PostgreSQL Installation in Progress" and I get a generic message: "There has been an error. foundation Installation Failed The application will exit now. When running the installer I have used the default location: /opt/ThingWorxFoundation. I am not able to see any logs (not even before i close the message error box). Also, i have found several topics open for issue with the installer and on one article (https://www.ptc.com/en/support/article/CS329897) i have even found the message: "
- Since ThingWorx Foundation 9.3.1 Installer, the log files are not deleted even after closing installer"
I didn't find any documentation on where or if the logs are saved when using centos8.
Do you know where i can find the logs or better yet, how can i fix this issue?
