Not sure what's the goal here.
Postgres 15.10 is a supported version for your version on ThingWorx. As such it will work with that database and you can rely on that.
Which postgres features it uses and which not are product internals that should not be of interest for you, also this can change at any time with every patch release.
If you must know, this would have to be answered by product management via a support ticket, but I doubt they will give out that information.
Thank you very much Mr. Rocko for the response,
We were trying to be cautious about the update, by covering all the possible errors that might come up when updating the PostgreSQL in our Cloud environment.
And you were right, we did manage to update all our environments with no problems or errors whatsoever.
And, sorry about the long time to respond to your post.
Kind Regards,
Alex
Hi @au_11038188
If you are satisfied with the response you received, please mark it as the Accepted Solution for the benefit of other community members.
--Sharon
