ThingWorx and Raspberry Pi Connectivity
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
Hello!
I connect Raspberry Pi to the platform thingWorx 8.1.2 to get the temperature and humidity values.
I reached the "Connections" step (all other steps were successfully completed).
According to the instruction, a "temperature-thing-jar-with-dependencies.fire" file is created, which must be copied to raspberry Pi.
Then I prescribe the command on the raspberry card:: java -jar ./temperature-thing-jar-with-dependencies.jar http://1XX.6X.3X.11X:8080/Thingworx 382fac73-e22e-435f-a44f-e74becc0a66d 2302 4 (Instead of X, normal numbers)
The result is an error:
02:48:26.096 [Client-EndpointMonitor-1] ERROR c.t.c.c.e.ClientCommunicationEndpoint - Refilling connections on [endpoint 0, uri: http://1XX.6X.3X.11X:8080/Thingworx] failed : timeout waiting for websocket handshake to complete
02:48:26.102 [Client-EndpointMonitor-1] ERROR c.t.c.c.e.ClientCommunicationEndpoint - Exception refilling connections was:
java.util.concurrent.TimeoutException: timeout waiting for websocket handshake to complete
at com.thingworx.communications.client.connection.netty.NettyClientConnectionFactory$HandshakeCompletionNotifier.await(NettyClientConnectionFactory.java:665) ~[temperature-thing-jar-with-dependencies.jar:na]
at com.thingworx.communications.client.connection.netty.NettyClientConnectionFactory.createConnection(NettyClientConnectionFactory.java:386) ~[temperature-thing-jar-with-dependencies.jar:na]
at com.thingworx.communications.client.endpoints.ClientCommunicationEndpoint.refillConnections(ClientCommunicationEndpoint.java:230) ~[temperature-thing-jar-with-dependencies.jar:na]
at com.thingworx.communications.common.endpoints.monitor.ConnectivityMonitorTask.dutyCycleOn(ConnectivityMonitorTask.java:159) [temperature-thing-jar-with-dependencies.jar:na]
at com.thingworx.communications.common.endpoints.monitor.ConnectivityMonitorTask.run(ConnectivityMonitorTask.java:306) [temperature-thing-jar-with-dependencies.jar:na]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [na:1.8.0_65]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [na:1.8.0_65]
at java.lang.Thread.run(Thread.java:745) [na:1.8.0_65]
I ask you to help with the solution of the problem. logs and others in the attachment.
- Labels:
Connectivity
- Tags:
- raspberry pi
- ws
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Andrey Tsarev: For the connectivity issue, could you please confirm if the appkey used is part of Administrator group. If not, then please create a new key with Administrator ID and see if it help resolve the issue. Also, which OS is been used on Raspberry Pi and do you see any network issue/firewall blocking tomcat port ?
-Durgesh
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Thanks for the answer. Yes, I connect as an administrator. And the key is set from the administrator account. On Raspberry Pi Linux is installed, and all ports are open.
