Hi Team,
I was doing a training for Analytics (https://community.ptc.com/t5/IoT-Tips/ThingWorx-Analytics-Training-Module-11-Part-1/ta-p/844948). I tried to import Things_dataSimulator.xml but the import failed. The error shown is:
Please help me solve this issue,
Thank you.
Amelia W
Hi @d_kessler
Could you help here.
It seems the Thing_dataSimulator.xml from ThingWorx Analytics Training: Module 11 Part 1 - PTC Community is missing the Thing Template DataSimulatorTemplate and so cannot be imported .
Are you able to locate it somewhere ?
Christophe
Hi @d_kessler
Christophe
Hi cmorfin,
Thank you for bringing this issue to my attention. I've responded to the original poster with the solution.
Best,
dkessler
Hi Amelia,
Thank you for bringing this to our attention. I was able to reproduce the error that you were seeing, and have built a new "DataSimulator_Standalone.xml" file that can be used instead of the old "Things_dataSimulator.xml". This new file has no dependencies on the Data Simulator Thing Template, so you should be able to import the new file without problems. I've replaced the old file with the new file in the page "https://community.ptc.com/t5/IoT-Tips/ThingWorx-Analytics-Training-Module-11-Part-1/ta-p/844948".
Please let me know if you encounter any other issues with this import.
Best,
dkessler
