How is ThingWorx beneficial for creating ERP applications, enterprise solutions, and non-IoT web development?
Can ThingWorx be used for building non-IoT web application use cases?
Take a look at Windchill Navigate, formerly ThingWorx Navigate, which is based on ThingWorx and implements a whole set of role-based apps focused on Digital Thread and PLM, mostly non-IoT use cases.
Hi @SM_13433996
It appears that this post may answers your question. For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
Abhi
