Hello ,
We have configured Thingworx 8.3 also we have installed ThingWorx analytics server .Thingworx analytic server installed without error and all services are up and running properly . But how to view through Thingworx composer . Also for Thingworx 8.3 docker is not coming with installable so could you please help me in configuring docker with thingworx 8.3.
Bhagyashree
You need to create Docker image for Thingworx in 8.3 version.
Please follow this guide:
https://www.ptc.com/support/-/media/67533E6ABFCB4BC9B9AA6C6CA6030A73.pdf?sc_lang=en
Hope it helps,
Raluca Edu
Hope it helps,
Raluca Edu
HI @bkulkarni.
If the response provided by Raluca answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
