Thingworx AZure iot connection issue
VS_10112707
1) Error injecting constructor, java.lang.RuntimeException: routing-group cannot be blank in configuration file
at com.thingworx.protocol.azure.iot.AzureIotHubBindService.<init>(AzureIotHubBindService.java:41)
at com.thingworx.protocol.azure.iot.AzureIotGuiceModule.configure(AzureIotGuiceModule.java:39)
while locating com.thingworx.protocol.azure.iot.AzureIotHubBindService
for the 6th parameter of com.thingworx.protocol.azure.iot.AzureIotProtocolAdapter.<init>(AzureIotProtocolAdapter.java:101)
while locating com.thingworx.protocol.azure.iot.AzureIotProtocolAdapter
while locating com.thingworx.connectionserver.protocol.Protocol
for the 9th parameter of com.thingworx.connectionserver.ConnectionServerDataPlane.<init>(ConnectionServerDataPlane.java:47)
at com.thingworx.connectionserver.ConnectionServerDataPlane.class(ConnectionServerDataPlane.java:25)
while locating com.thingworx.connectionserver.ConnectionServerDataPlane
at com.thingworx.connectionserver.ConnectionServerModule.configure(ConnectionServerModule.java:72)
while locating com.thingworx.statemachine.DataPlane
Caused by: java.lang.RuntimeException: routing-group cannot be blank in configuration file
at com.thingworx.protocol.azure.iot.AzureIotHubBindService.loadRoutingGroup(AzureIotHubBindService.java:163)
at com.thingworx.protocol.azure.iot.AzureIotHubBindService.<init>(AzureIotHubBindService.java:44)
at com.thingworx.protocol.azure.iot.AzureIotHubBindService$$FastClassByGuice$$51158f68.newInstance(<generated>)
at com.google.inject.internal.DefaultConstructionProxyFactory$FastClassProxy.newInstance(DefaultConstructionProxyFactory.java:89)
at com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:111)
at com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:90)
at com.google.inject.internal.ConstructorBindingImpl$Factory.get(ConstructorBindingImpl.java:268)
at com.google.inject.internal.ProviderToInternalFactoryAdapter$1.call(ProviderToInternalFactoryAdapter.java:46)
at com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1092)
at com.google.inject.internal.ProviderToInternalFactoryAdapter.get(ProviderToInternalFactoryAdapter.java:40)
at com.google.inject.internal.SingletonScope$1.get(SingletonScope.java:194)
at com.google.inject.internal.InternalFactoryToProviderAdapter.get(InternalFactoryToProviderAdapter.java:41)
at com.google.inject.internal.SingleParameterInjector.inject(SingleParameterInjector.java:38)
at com.google.inject.internal.SingleParameterInjector.getAll(SingleParameterInjector.java:62)
at com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:110)
at com.google.inject.internal.FactoryProxy.get(FactoryProxy.java:56)
at com.google.inject.internal.InternalInjectorCreator$1.call(InternalInjectorCreator.java:205)
at com.google.inject.internal.InternalInjectorCreator$1.call(InternalInjectorCreator.java:199)
at com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1085)
at com.google.inject.internal.InternalInjectorCreator.loadEagerSingletons(InternalInjectorCreator.java:199)
at com.google.inject.internal.InternalInjectorCreator.injectDynamically(InternalInjectorCreator.java:180)
at com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:110)
at com.google.inject.Guice.createInjector(Guice.java:99)
at com.thingworx.connectionserver.ConnectionServer.createControlPlane(ConnectionServer.java:96)
at com.thingworx.connectionserver.ConnectionServer.start(ConnectionServer.java:111)
at com.thingworx.connectionserver.ConnectionServer.main(ConnectionServer.java:198)
2) Error injecting constructor, java.lang.RuntimeException: routing-group cannot be blank in configuration file
3) Error injecting constructor, java.lang.RuntimeException: routing-group cannot be blank in configuration file
3 errors
at com.google.inject.internal.Errors.throwCreationExceptionIfErrorsExist(Errors.java:470)
at com.google.inject.internal.InternalInjectorCreator.injectDynamically(InternalInjectorCreator.java:184)
Read the following article - "Azure IoT Hub Connector 3.0 is showing "Missing application key" and "routing-group cannot be blank in configuration file" errors when connecting to ThingWorx Platform 8.5": https://www.ptc.com/en/support/article/cs316161
