I am unable to find the Thingworx Analaytic Extension, Please drop it here if you have.
Thanks in Advance
Can i get the extension.
Hi @AS_1307
The access to the ThingWorx Analytics product and its extension is subject to licensing.
If you think you should have access to it, I would recommend you open a case to license management to check their record as it does happen that the tool is not up to date.
Thank you
Kind regards
Christophe
