I am setting up Thingworx Analytics 52.2. I followed the installation guides, but I am facing issues with the last step: Installation of UploadThing
I am using thingworx on port 8081 with SSL. I have attached the uploadthing.log file and the UploadThing.properties file for reference.
I would appreciate any help regarding the same.
Thanks & Regards,
Madhumita Deshpande
Hi Madhumita,
I found this KCS article that I believe solves the issue you are encountering.
Let me know if this solves the error that you are encountering.
John
Hi John,
I followed the steps in the article,but it is still not working.
Is there any other solution? Is the problem related to SSL(I'm using Thingworx with SSL)?
I would appreciate any help.
Thanks & Regards,
Madhumita
Hi Madhumita,
I will reach out to the R&D team to see if using ThingWorx with SSL is causing the issue.
Let me know if you have any further questions or concerns.
John
Hi Madhumita,
I have sent an email to the address that I believe is yours. Please respond to it if you did get it or let me know through here if you did not.
John
