I trie to re-run the same workflow but with different inputs parameters while the one is not finished yet
I use a simple workflow , using webhook as input . The flow use only log and delay boxs.
I use postman to start the flow . The first flow is started .
When i send again a new post before the first flow is not finished . The flow is never re-executed
