Is it possible to connect Azure IoT Hub to a Thingworx Hosted Server (ie.,
https://PP-180495016FP.devportal.ptc.io/Thingworx)
The guide here: https://developer.thingworx.com/resources/guides/azure-iot-hub-connector-quickstart/install-iot-hub-connector seems to be related to a local instance of ThingWorx, rather than one hosted...so wasn't sure if this was possible?
Thanks!
Yes, you can use the Azure IoT Connector with the free trial instance of ThingWorx Foundation. In addition to a Foundation instance, you need another computer to run the Azure IoT Connector application. The guide walks through setting-up and running the Azure IoT Connector and gives instructions for both Windows and Linux
Hi @brian570.
If the response provided by Al answered your question, please mark it as the Accepted Solution for the benefit of others who may have the same question.
Regards.
--Sharon
