Hi Team,
What SQL Commands can be used to Change the Collation/COLLATE of the MS SQL SB?
Ahh found this work around quick, below are the commands need to be used as soon as the MS SQL DB is setup:
ALTER DATABASE thingworxv1 SET SINGLE_USER WITH ROLLBACK IMMEDIATE;
ALTER DATABASE thingworxv1 COLLATE Latin1_General_100_CS_AS_SC;
ALTER DATABASE thingworxv1 SET MULTI_USER;
Change the "thingworxv1" with your database.
After the executing these commands, the then COLLATE should be good for the schema setup and Thingworx Installation
