Thingworx Server running but cannot access web pages
ehalvordsson
We have bumped into a strange problem that probably occured during an update of Windows Server 2016.
Thingworx and Tomcat appear to be running (ApplicationLog.log is continuously updating events) but we are unable to access the web pages, neither for Tomcat Manager nor for Thingworx. The problem seems to be related to Thingworx and not to the network and we have verified this by removing Thingworx and starting Tomcat Manager only.
The service status stays in "Started" and does not go into "running"
The catalina.log does not show any errors.
Tested with Tomcat 8.5.29 / 31 and Thingworx 8.2.2 and 8.3.0, Oracle Java JDK 1.8.0_161 and 171
Did you experience something similar or have any ideas on what we could try in order to recover the server?
ehalvordsson
(To:PaiChung)
Thanks. We upgraded and did a clean re-install on the server.
8 REPLIES 8
PaiChung
22-Sapphire I
(To:ehalvordsson)
What message do you receive when you try to get to the pages?
Can you get to the main Tomcat page? (since you mentioned manager)
Also are you specifying the appropriate port (if you aren't running on 80 or 443)
ehalvordsson
(To:PaiChung)
Hi Pai,
Thanks for your help.
We get a timeout
We are not able to access anything, also not the blank page. However we can see that the Thingworx log keeps updating so it is "alive" to some extent.
The server is set up for port 80 and it works fine if we remove Thingworx from the Tomcat folder.
Best regards Erik
vxavier
(To:ehalvordsson)
Hi Erik,
What does it write in the thingworx application log?
Vinicius.
måkerman
(To:vxavier)
Hi!
I have atteched all the logs with some content including the application log.
/Magnus (Co-Worker with Erik)
PaiChung
22-Sapphire I
(To:måkerman)
Is this a trial instance that expired? Sorry looks weird, looks like after a few tries it actually started up, but is having some issues.
ehalvordsson
(To:PaiChung)
Hi Pai,
We updated with a new license request and we have the same issue - the server seems to be running but the web access is not working. The application log looks similar, no errors related to the licensing or server.
We will save a backup of this server now and do a complete re-install.
PaiChung
22-Sapphire I
(To:ehalvordsson)
I recommend you get Technical Support involved with this, sorry :(
ehalvordsson
(To:PaiChung)
