('Unable to Invoke Service SpotlightSearch on SearchFunctions : Unable to get search entries: [2,006] Unknown error occurred. Contact the administrator if this re-occurs.') I am facing the error in thingworx. The thingworx version is 8.2.2
Even if ThingWorx 8.2.2 is out of support since a long time, after searching support.ptc.com I was able to find the following article: https://www.ptc.com/en/support/article/CS341041?source=search
Can you please read it and let us know if it helped you?
