Hi Developers,
I have a service which loads the data on mashup in gridadvanced. I have a textfield which takes searchinput so
if (searchinput !== "") {
then i run the service to get data for that input which is given in text field
else if (searchinput === ""){
means i have not written anything in textfield then i am just showing a complete datatable entries on grid
Now new requirement came that the user can select startdate enddate and get that entries on mashup. Any suggestions for best practices how can i do that? I think i have limited the existing service to run on only in two conditions. how can i expand it. any ideas or suggestions?
How do you query the data with Start Date and End Date?
Query the data with the filter "searchinput", "Start Date" and "End Date"
Query the data with "Start Date" and "End Date" only
