The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
I have problem in launching Thingworx through tomcat.This is the log i get.
04-Apr-2018 13:45:38.340 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version: Apache Tomcat/8.0.15
04-Apr-2018 13:45:38.340 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built: Nov 2 2014 19:25:20 UTC
04-Apr-2018 13:45:38.340 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server number: 8.0.15.0
04-Apr-2018 13:45:38.340 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name: Windows 7
04-Apr-2018 13:45:38.340 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version: 6.1
04-Apr-2018 13:45:38.340 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture: amd64
04-Apr-2018 13:45:38.340 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JAVA_HOME: C:\Program Files\Java\jre1.8.0_121
04-Apr-2018 13:45:38.340 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 1.8.0_121-b13
04-Apr-2018 13:45:38.340 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor: Oracle Corporation
04-Apr-2018 13:45:38.340 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE: C:\Program Files\Apache Software Foundation\Tomcat 8.0
04-Apr-2018 13:45:38.340 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME: C:\Program Files\Apache Software Foundation\Tomcat 8.0
04-Apr-2018 13:45:38.340 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=C:\Program Files\Apache Software Foundation\Tomcat 8.0
04-Apr-2018 13:45:38.340 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=C:\Program Files\Apache Software Foundation\Tomcat 8.0
04-Apr-2018 13:45:38.340 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.endorsed.dirs=C:\Program Files\Apache Software Foundation\Tomcat 8.0\endorsed
04-Apr-2018 13:45:38.340 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=C:\Program Files\Apache Software Foundation\Tomcat 8.0\temp
04-Apr-2018 13:45:38.340 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
04-Apr-2018 13:45:38.340 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=C:\Program Files\Apache Software Foundation\Tomcat 8.0\conf\logging.properties
04-Apr-2018 13:45:38.340 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dserver -Dd64
04-Apr-2018 13:45:38.340 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+UseG1GC
04-Apr-2018 13:45:38.340 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dfile.encoding=UTF-8
04-Apr-2018 13:45:38.340 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.library.path=C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\Thingworx\WEB-INF\extensions
04-Apr-2018 13:45:38.340 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: exit
04-Apr-2018 13:45:38.340 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\Thingworx\WEB-INF\extensions
04-Apr-2018 13:45:38.440 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8080"]
04-Apr-2018 13:45:38.560 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
04-Apr-2018 13:45:38.560 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["ajp-nio-8009"]
04-Apr-2018 13:45:38.560 INFO [main] org.apache.catalina.startup.Catalina.load Initialization processed in 493 ms
04-Apr-2018 13:45:38.580 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service Catalina
04-Apr-2018 13:45:38.580 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet Engine: Apache Tomcat/8.0.15
04-Apr-2018 13:45:38.600 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deploying web application archive C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\Thingworx.war
04-Apr-2018 13:45:47.855 SEVERE [localhost-startStop-1] org.apache.catalina.core.StandardContext.startInternal Error filterStart
04-Apr-2018 13:45:47.855 SEVERE [localhost-startStop-1] org.apache.catalina.core.StandardContext.startInternal Context [/Thingworx] startup failed due to previous errors
04-Apr-2018 13:45:47.913 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deployment of web application archive C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\Thingworx.war has finished in 9,313 ms
04-Apr-2018 13:45:47.914 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\docs
04-Apr-2018 13:45:47.939 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\docs has finished in 25 ms
04-Apr-2018 13:45:47.939 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\manager
04-Apr-2018 13:45:47.958 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\manager has finished in 18 ms
04-Apr-2018 13:45:47.958 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\ROOT
04-Apr-2018 13:45:47.973 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\ROOT has finished in 15 ms
04-Apr-2018 13:45:47.976 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio-8080"]
04-Apr-2018 13:45:47.985 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["ajp-nio-8009"]
04-Apr-2018 13:45:47.988 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in 9439 ms
Hi
So the error is
ErrorLog.com.thingworx.security.authentication.HAAuthenticationFilter - Failed to initialize HA Authentication
java.lang.IllegalArgumentException: password can't be null
at com.sun.crypto.provider.KeyProtector.<init>(KeyProtector.java:86)
at com.sun.crypto.provider.JceKeyStore.engineGetKey(JceKeyStore.java:117)
at java.security.KeyStore.getKey(Unknown Source)
at com.thingworx.security.keystore.ThingworxKeyStore.getEntry(ThingworxKeyStore.java:223)
at com.thingworx.system.configuration.PlatformSettings.<init>(PlatformSettings.java:693)
at com.thingworx.system.configuration.PlatformSettings.getInstance(PlatformSettings.java:1082)
A few points that may help
- check the platform-settings.json file to ensure it has got correct settings
- we have seen this error on servers with multiple instances of ThingWorx that were conflicting each other. If that is your case, you may want to double check each environment is well setup in term of env variables for example, and possibly install on a fresh machine, at least as a troubleshooting step
- if that is a new installation, delete <ThingWorx Platform>/keystore-password and <ThingWorxStorage>/keystore.jks
- ensure your license file is correct, maybe re-download it from the License management portal
hope this helps
Christophe
Hi @se1 is this a fresh installation? Which persistence provider are you using for ThingWorx? Can you attach complete catalina.out log together with ThingWorx's applicationLog.log if it has been generate?
Thanks for response @supandey
//Catalina log
19-Apr-2018 12:28:37.549 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version: Apache Tomcat/8.0.15 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built: Nov 2 2014 19:25:20 UTC 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server number: 8.0.15.0 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name: Windows 7 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version: 6.1 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture: amd64 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JAVA_HOME: C:\Program Files\Java\jre1.8.0_121 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 1.8.0_121-b13 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor: Oracle Corporation 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE: C:\Program Files\Apache Software Foundation\Tomcat 8.0 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME: C:\Program Files\Apache Software Foundation\Tomcat 8.0 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=C:\Program Files\Apache Software Foundation\Tomcat 8.0 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=C:\Program Files\Apache Software Foundation\Tomcat 8.0 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.endorsed.dirs=C:\Program Files\Apache Software Foundation\Tomcat 8.0\endorsed 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=C:\Program Files\Apache Software Foundation\Tomcat 8.0\temp 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=C:\Program Files\Apache Software Foundation\Tomcat 8.0\conf\logging.properties 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dserver -Dd64 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+UseG1GC 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dfile.encoding=UTF-8 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.library.path=\webapps\Thingworx\WEB-INF\extensions 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: exit 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: \webapps\Thingworx\WEB-INF\extensions 19-Apr-2018 12:28:37.649 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8080"] 19-Apr-2018 12:28:37.779 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read 19-Apr-2018 12:28:37.779 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["ajp-nio-8009"] 19-Apr-2018 12:28:37.779 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read 19-Apr-2018 12:28:37.779 INFO [main] org.apache.catalina.startup.Catalina.load Initialization processed in 497 ms 19-Apr-2018 12:28:37.799 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service Catalina 19-Apr-2018 12:28:37.799 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet Engine: Apache Tomcat/8.0.15 19-Apr-2018 12:28:37.819 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deploying web application archive C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\Thingworx.war 19-Apr-2018 12:28:46.862 SEVERE [localhost-startStop-1] org.apache.catalina.core.StandardContext.startInternal Error filterStart 19-Apr-2018 12:28:46.862 SEVERE [localhost-startStop-1] org.apache.catalina.core.StandardContext.startInternal Context [/Thingworx] startup failed due to previous errors 19-Apr-2018 12:28:46.929 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deployment of web application archive C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\Thingworx.war has finished in 9,110 ms 19-Apr-2018 12:28:46.929 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\docs 19-Apr-2018 12:28:46.949 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\docs has finished in 20 ms 19-Apr-2018 12:28:46.949 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\manager 19-Apr-2018 12:28:46.969 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\manager has finished in 20 ms 19-Apr-2018 12:28:46.969 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\ROOT 19-Apr-2018 12:28:46.979 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\ROOT has finished in 10 ms 19-Apr-2018 12:28:46.989 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio-8080"] 19-Apr-2018 12:28:46.989 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["ajp-nio-8009"] 19-Apr-2018 12:28:46.999 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in 9213 ms 19-Apr-2018 12:30:11.658 INFO [Thread-7] org.apache.coyote.AbstractProtocol.pause Pausing ProtocolHandler ["http-nio-8080"] 19-Apr-2018 12:30:11.718 INFO [Thread-7] org.apache.coyote.AbstractProtocol.pause Pausing ProtocolHandler ["ajp-nio-8009"] 19-Apr-2018 12:30:11.768 INFO [Thread-7] org.apache.catalina.core.StandardService.stopInternal Stopping service Catalina 19-Apr-2018 12:30:11.808 INFO [Thread-7] org.apache.coyote.AbstractProtocol.stop Stopping ProtocolHandler ["http-nio-8080"] 19-Apr-2018 12:30:11.808 INFO [Thread-7] org.apache.coyote.AbstractProtocol.stop Stopping ProtocolHandler ["ajp-nio-8009"] 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version: Apache Tomcat/8.0.15 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built: Nov 2 2014 19:25:20 UTC 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server number: 8.0.15.0 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name: Windows 7 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version: 6.1 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture: amd64 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JAVA_HOME: C:\Program Files\Java\jre1.8.0_121 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 1.8.0_121-b13 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor: Oracle Corporation 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE: C:\Program Files\Apache Software Foundation\Tomcat 8.0 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME: C:\Program Files\Apache Software Foundation\Tomcat 8.0 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=C:\Program Files\Apache Software Foundation\Tomcat 8.0 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=C:\Program Files\Apache Software Foundation\Tomcat 8.0 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.endorsed.dirs=C:\Program Files\Apache Software Foundation\Tomcat 8.0\endorsed 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=C:\Program Files\Apache Software Foundation\Tomcat 8.0\temp 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=C:\Program Files\Apache Software Foundation\Tomcat 8.0\conf\logging.properties 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dserver -Dd64 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+UseG1GC 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dfile.encoding=UTF-8 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.library.path=C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\Thingworx\WEB-INF\extensions 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: exit 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\Thingworx\WEB-INF\extensions 19-Apr-2018 12:30:53.832 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8080"] 19-Apr-2018 12:30:53.962 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read 19-Apr-2018 12:30:53.962 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["ajp-nio-8009"] 19-Apr-2018 12:30:53.962 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read 19-Apr-2018 12:30:53.962 INFO [main] org.apache.catalina.startup.Catalina.load Initialization processed in 494 ms 19-Apr-2018 12:30:53.982 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service Catalina 19-Apr-2018 12:30:53.982 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet Engine: Apache Tomcat/8.0.15 19-Apr-2018 12:30:54.002 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deploying web application archive C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\Thingworx.war 19-Apr-2018 12:31:03.282 SEVERE [localhost-startStop-1] org.apache.catalina.core.StandardContext.startInternal Error filterStart 19-Apr-2018 12:31:03.283 SEVERE [localhost-startStop-1] org.apache.catalina.core.StandardContext.startInternal Context [/Thingworx] startup failed due to previous errors 19-Apr-2018 12:31:03.340 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deployment of web application archive C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\Thingworx.war has finished in 9,337 ms 19-Apr-2018 12:31:03.340 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\docs 19-Apr-2018 12:31:03.364 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\docs has finished in 24 ms 19-Apr-2018 12:31:03.364 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\manager 19-Apr-2018 12:31:03.383 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\manager has finished in 19 ms 19-Apr-2018 12:31:03.383 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\ROOT 19-Apr-2018 12:31:03.400 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\ROOT has finished in 17 ms 19-Apr-2018 12:31:03.405 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio-8080"] 19-Apr-2018 12:31:03.411 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["ajp-nio-8009"] 19-Apr-2018 12:31:03.415 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in 9462 ms
//Application log is not generated.
Hi
Can you please attach all the Tomcat log files (catalina*, localhost*, std* ...)
Christophe
Thank You response @cmorfin.
//catalina
19-Apr-2018 12:28:37.549 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version: Apache Tomcat/8.0.15 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built: Nov 2 2014 19:25:20 UTC 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server number: 8.0.15.0 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name: Windows 7 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version: 6.1 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture: amd64 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JAVA_HOME: C:\Program Files\Java\jre1.8.0_121 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 1.8.0_121-b13 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor: Oracle Corporation 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE: C:\Program Files\Apache Software Foundation\Tomcat 8.0 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME: C:\Program Files\Apache Software Foundation\Tomcat 8.0 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=C:\Program Files\Apache Software Foundation\Tomcat 8.0 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=C:\Program Files\Apache Software Foundation\Tomcat 8.0 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.endorsed.dirs=C:\Program Files\Apache Software Foundation\Tomcat 8.0\endorsed 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=C:\Program Files\Apache Software Foundation\Tomcat 8.0\temp 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=C:\Program Files\Apache Software Foundation\Tomcat 8.0\conf\logging.properties 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dserver -Dd64 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+UseG1GC 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dfile.encoding=UTF-8 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.library.path=\webapps\Thingworx\WEB-INF\extensions 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: exit 19-Apr-2018 12:28:37.559 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: \webapps\Thingworx\WEB-INF\extensions 19-Apr-2018 12:28:37.649 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8080"] 19-Apr-2018 12:28:37.779 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read 19-Apr-2018 12:28:37.779 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["ajp-nio-8009"] 19-Apr-2018 12:28:37.779 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read 19-Apr-2018 12:28:37.779 INFO [main] org.apache.catalina.startup.Catalina.load Initialization processed in 497 ms 19-Apr-2018 12:28:37.799 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service Catalina 19-Apr-2018 12:28:37.799 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet Engine: Apache Tomcat/8.0.15 19-Apr-2018 12:28:37.819 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deploying web application archive C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\Thingworx.war 19-Apr-2018 12:28:46.862 SEVERE [localhost-startStop-1] org.apache.catalina.core.StandardContext.startInternal Error filterStart 19-Apr-2018 12:28:46.862 SEVERE [localhost-startStop-1] org.apache.catalina.core.StandardContext.startInternal Context [/Thingworx] startup failed due to previous errors 19-Apr-2018 12:28:46.929 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deployment of web application archive C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\Thingworx.war has finished in 9,110 ms 19-Apr-2018 12:28:46.929 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\docs 19-Apr-2018 12:28:46.949 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\docs has finished in 20 ms 19-Apr-2018 12:28:46.949 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\manager 19-Apr-2018 12:28:46.969 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\manager has finished in 20 ms 19-Apr-2018 12:28:46.969 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\ROOT 19-Apr-2018 12:28:46.979 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\ROOT has finished in 10 ms 19-Apr-2018 12:28:46.989 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio-8080"] 19-Apr-2018 12:28:46.989 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["ajp-nio-8009"] 19-Apr-2018 12:28:46.999 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in 9213 ms 19-Apr-2018 12:30:11.658 INFO [Thread-7] org.apache.coyote.AbstractProtocol.pause Pausing ProtocolHandler ["http-nio-8080"] 19-Apr-2018 12:30:11.718 INFO [Thread-7] org.apache.coyote.AbstractProtocol.pause Pausing ProtocolHandler ["ajp-nio-8009"] 19-Apr-2018 12:30:11.768 INFO [Thread-7] org.apache.catalina.core.StandardService.stopInternal Stopping service Catalina 19-Apr-2018 12:30:11.808 INFO [Thread-7] org.apache.coyote.AbstractProtocol.stop Stopping ProtocolHandler ["http-nio-8080"] 19-Apr-2018 12:30:11.808 INFO [Thread-7] org.apache.coyote.AbstractProtocol.stop Stopping ProtocolHandler ["ajp-nio-8009"] 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version: Apache Tomcat/8.0.15 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built: Nov 2 2014 19:25:20 UTC 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server number: 8.0.15.0 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name: Windows 7 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version: 6.1 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture: amd64 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JAVA_HOME: C:\Program Files\Java\jre1.8.0_121 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 1.8.0_121-b13 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor: Oracle Corporation 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE: C:\Program Files\Apache Software Foundation\Tomcat 8.0 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME: C:\Program Files\Apache Software Foundation\Tomcat 8.0 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=C:\Program Files\Apache Software Foundation\Tomcat 8.0 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=C:\Program Files\Apache Software Foundation\Tomcat 8.0 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.endorsed.dirs=C:\Program Files\Apache Software Foundation\Tomcat 8.0\endorsed 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=C:\Program Files\Apache Software Foundation\Tomcat 8.0\temp 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=C:\Program Files\Apache Software Foundation\Tomcat 8.0\conf\logging.properties 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dserver -Dd64 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+UseG1GC 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dfile.encoding=UTF-8 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.library.path=C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\Thingworx\WEB-INF\extensions 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: exit 19-Apr-2018 12:30:53.742 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\Thingworx\WEB-INF\extensions 19-Apr-2018 12:30:53.832 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8080"] 19-Apr-2018 12:30:53.962 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read 19-Apr-2018 12:30:53.962 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["ajp-nio-8009"] 19-Apr-2018 12:30:53.962 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read 19-Apr-2018 12:30:53.962 INFO [main] org.apache.catalina.startup.Catalina.load Initialization processed in 494 ms 19-Apr-2018 12:30:53.982 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service Catalina 19-Apr-2018 12:30:53.982 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet Engine: Apache Tomcat/8.0.15 19-Apr-2018 12:30:54.002 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deploying web application archive C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\Thingworx.war 19-Apr-2018 12:31:03.282 SEVERE [localhost-startStop-1] org.apache.catalina.core.StandardContext.startInternal Error filterStart 19-Apr-2018 12:31:03.283 SEVERE [localhost-startStop-1] org.apache.catalina.core.StandardContext.startInternal Context [/Thingworx] startup failed due to previous errors 19-Apr-2018 12:31:03.340 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deployment of web application archive C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\Thingworx.war has finished in 9,337 ms 19-Apr-2018 12:31:03.340 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\docs 19-Apr-2018 12:31:03.364 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\docs has finished in 24 ms 19-Apr-2018 12:31:03.364 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\manager 19-Apr-2018 12:31:03.383 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\manager has finished in 19 ms 19-Apr-2018 12:31:03.383 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\ROOT 19-Apr-2018 12:31:03.400 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\ROOT has finished in 17 ms 19-Apr-2018 12:31:03.405 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio-8080"] 19-Apr-2018 12:31:03.411 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["ajp-nio-8009"] 19-Apr-2018 12:31:03.415 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in 9462 ms 19-Apr-2018 17:26:39.575 INFO [Thread-7] org.apache.coyote.AbstractProtocol.pause Pausing ProtocolHandler ["http-nio-8080"] 19-Apr-2018 17:26:39.638 INFO [Thread-7] org.apache.coyote.AbstractProtocol.pause Pausing ProtocolHandler ["ajp-nio-8009"] 19-Apr-2018 17:26:39.690 INFO [Thread-7] org.apache.catalina.core.StandardService.stopInternal Stopping service Catalina 19-Apr-2018 17:26:39.737 INFO [Thread-7] org.apache.coyote.AbstractProtocol.stop Stopping ProtocolHandler ["http-nio-8080"] 19-Apr-2018 17:26:39.739 INFO [Thread-7] org.apache.coyote.AbstractProtocol.stop Stopping ProtocolHandler ["ajp-nio-8009"]
//COMMON_DAEMONS
[2018-04-19 12:28:36] [info] [ 3808] Commons Daemon procrun (1.0.15.0 64-bit) started
[2018-04-19 12:28:37] [info] [ 3808] Running 'Tomcat8' Service...
[2018-04-19 12:28:37] [info] [ 2976] Starting service...
[2018-04-19 12:28:38] [info] [ 2976] Service started in 1146 ms.
[2018-04-19 12:30:11] [info] [ 8412] Stopping service...
[2018-04-19 12:30:12] [info] [ 8412] Service stop thread completed.
[2018-04-19 12:30:12] [info] [ 3808] Run service finished.
[2018-04-19 12:30:13] [info] [ 3808] Commons Daemon procrun finished
[2018-04-19 12:30:53] [info] [ 5032] Commons Daemon procrun (1.0.15.0 64-bit) started
[2018-04-19 12:30:53] [info] [ 5032] Running 'Tomcat8' Service...
[2018-04-19 12:30:53] [info] [ 9184] Starting service...
[2018-04-19 12:30:54] [info] [ 9184] Service started in 1165 ms.
[2018-04-19 17:26:39] [info] [ 9664] Stopping service...
[2018-04-19 17:26:40] [info] [ 9664] Service stop thread completed.
[2018-04-19 17:26:40] [info] [ 5032] Run service finished.
[2018-04-19 17:26:40] [info] [ 5032] Commons Daemon procrun finished
//HOST_MANAGER and MANAGER is empty.
//LOCAL HOST.
19-Apr-2018 12:28:46.601 INFO [localhost-startStop-1] org.apache.catalina.core.ApplicationContext.log No Spring WebApplicationInitializer types detected on classpath
19-Apr-2018 12:28:46.862 SEVERE [localhost-startStop-1] org.apache.catalina.core.StandardContext.filterStart Exception starting filter HAAuthenticationFilter
javax.servlet.ServletException: java.lang.IllegalArgumentException: password can't be null
at com.thingworx.security.authentication.HAAuthenticationFilter.init(HAAuthenticationFilter.java:49)
at org.apache.catalina.core.ApplicationFilterConfig.initFilter(ApplicationFilterConfig.java:279)
at org.apache.catalina.core.ApplicationFilterConfig.getFilter(ApplicationFilterConfig.java:260)
at org.apache.catalina.core.ApplicationFilterConfig.<init>(ApplicationFilterConfig.java:105)
at org.apache.catalina.core.StandardContext.filterStart(StandardContext.java:4615)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5222)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:725)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:701)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:714)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:917)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1701)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.IllegalArgumentException: password can't be null
at com.thingworx.security.authentication.HAAuthenticationFilter.init(HAAuthenticationFilter.java:36)
... 16 more
19-Apr-2018 12:28:46.919 SEVERE [localhost-startStop-1] org.apache.catalina.core.StandardContext.listenerStop Exception sending context destroyed event to listener instance of class com.thingworx.system.ThingWorxBootstrapper
java.lang.NullPointerException
at com.thingworx.system.ThingWorxBootstrapper.contextDestroyed(ThingWorxBootstrapper.java:311)
at org.apache.catalina.core.StandardContext.listenerStop(StandardContext.java:4813)
at org.apache.catalina.core.StandardContext.stopInternal(StandardContext.java:5413)
at org.apache.catalina.util.LifecycleBase.stop(LifecycleBase.java:232)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:160)
19-Apr-2018 12:31:03.031 INFO [localhost-startStop-1] org.apache.catalina.core.ApplicationContext.log No Spring WebApplicationInitializer types detected on classpath
19-Apr-2018 12:31:03.282 SEVERE [localhost-startStop-1] org.apache.catalina.core.StandardContext.filterStart Exception starting filter HAAuthenticationFilter
... 16 more
19-Apr-2018 12:31:03.331 SEVERE [localhost-startStop-1] org.apache.catalina.core.StandardContext.listenerStop Exception sending context destroyed event to listener instance of class com.thingworx.system.ThingWorxBootstrapper
//local host access log
0:0:0:0:0:0:0:1 - - [19/Apr/2018:12:28:55 +0530] "GET / HTTP/1.1" 200 11452
0:0:0:0:0:0:0:1 - - [19/Apr/2018:12:31:03 +0530] "GET / HTTP/1.1" 200 11452
0:0:0:0:0:0:0:1 - - [19/Apr/2018:12:31:03 +0530] "GET /tomcat.png HTTP/1.1" 304 -
0:0:0:0:0:0:0:1 - - [19/Apr/2018:12:31:03 +0530] "GET /tomcat.css HTTP/1.1" 304 -
0:0:0:0:0:0:0:1 - - [19/Apr/2018:12:31:03 +0530] "GET /favicon.ico HTTP/1.1" 200 21630
0:0:0:0:0:0:0:1 - - [19/Apr/2018:12:31:12 +0530] "GET /Thingworx HTTP/1.1" 404 1012
0:0:0:0:0:0:0:1 - - [19/Apr/2018:12:36:04 +0530] "GET / HTTP/1.1" 200 11452
0:0:0:0:0:0:0:1 - - [19/Apr/2018:12:36:13 +0530] "GET /Thingworx HTTP/1.1" 404 1012
0:0:0:0:0:0:0:1 - - [19/Apr/2018:12:36:17 +0530] "GET /Thingworx/ HTTP/1.1" 404 1014
//tomcat_stderr
2018-04-19 12:28:37 Commons Daemon procrun stderr initialized
2018-04-19 12:30:53 Commons Daemon procrun stderr initialized
//tomcat_stdout
2018-04-19 12:28:37 Commons Daemon procrun stdout initialized
12:28:46.701 [localhost-startStop-1] ERROR com.thingworx.system.ThingWorxBootstrapper - [message: password can't be null]
at com.thingworx.system.ThingWorxBootstrapper.contextInitialized(ThingWorxBootstrapper.java:74)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4772)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5196)
*** CRITICAL ERROR ON STARTUP: password can't be null
12:28:46.741 [localhost-startStop-1] ERROR SecurityLog.com.thingworx.webservices.context.ThreadLocalContext - Failed to retrieve SSOContext
12:28:46.741 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.utils.Log - logLevel set to slf4j
12:28:46.741 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.UrlRewriteFilter - confPath set to /WEB-INF/urlrewrite-rewrite.xml
12:28:46.761 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.Conf - XML builder factory is: com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderFactoryImpl
12:28:46.761 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.Conf - XML Parser: com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl
12:28:46.761 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.Conf - about to parse conf
12:28:46.771 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.ConfHandler - Resolving to DTD /org/tuckey/web/filters/urlrewrite/dtds/urlrewrite4.0.dtd
12:28:46.781 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.Conf - now initialising conf
12:28:46.791 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.Condition - loaded condition header Authorization ^Bearer\s+.*$
12:28:46.791 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.Condition - loaded condition attribute _is_rewritten_ true
12:28:46.791 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.RuleBase - loaded rule rp-url-rewrite (rule 0) (^/(?!rp/.*), /rp/$0 1)
12:28:46.791 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.NormalRule - loaded rule rp-url-rewrite (rule 0) (^/(?!rp/.*), /rp/$0 1)
12:28:46.791 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.Conf - conf status true
12:28:46.791 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.UrlRewriteFilter - inited with 1 rules
12:28:46.791 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.UrlRewriteFilter - conf is ok
12:28:46.791 [localhost-startStop-1] INFO org.tuckey.web.filters.urlrewrite.UrlRewriteFilter - loaded (conf ok)
12:28:46.791 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.UrlRewriteFilter - filter init called
12:28:46.791 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.UrlRewriteFilter - init: calling destroy just in case we are being re-inited uncleanly
12:28:46.791 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.utils.Log - logLevel set to slf4j
12:28:46.791 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.UrlRewriteFilter - confPath set to /WEB-INF/urlrewrite-restore.xml
12:28:46.791 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.Conf - XML builder factory is: com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderFactoryImpl
12:28:46.791 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.Conf - XML Parser: com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl
12:28:46.791 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.Conf - about to parse conf
12:28:46.791 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.ConfHandler - Resolving to DTD /org/tuckey/web/filters/urlrewrite/dtds/urlrewrite4.0.dtd
12:28:46.801 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.Conf - now initialising conf
12:28:46.801 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.RuleBase - loaded rule rp-url-restore (rule 0) (^/rp/(.*)$, /$1 1)
12:28:46.801 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.NormalRule - loaded rule rp-url-restore (rule 0) (^/rp/(.*)$, /$1 1)
12:28:46.801 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.Conf - conf status true
12:28:46.801 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.UrlRewriteFilter - inited with 1 rules
12:28:46.801 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.UrlRewriteFilter - conf is ok
12:28:46.801 [localhost-startStop-1] INFO org.tuckey.web.filters.urlrewrite.UrlRewriteFilter - loaded (conf ok)
12:28:46.861 [localhost-startStop-1] ERROR SecurityLog.com.thingworx.security.authentication.AuthenticationFilter - Could not load session timeout from database, using default: null
12:28:46.862 [localhost-startStop-1] ERROR ErrorLog.com.thingworx.security.authentication.HAAuthenticationFilter - Failed to initialize HA Authentication
12:28:46.862 [localhost-startStop-1] INFO org.tuckey.web.filters.urlrewrite.UrlRewriteFilter - destroy called
org.tuckey.web.filters.urlrewrite.UrlRewriteFilter INFO: destroy called
2018-04-19 12:30:53 Commons Daemon procrun stdout initialized
12:31:03.126 [localhost-startStop-1] ERROR com.thingworx.system.ThingWorxBootstrapper - [message: password can't be null]
12:31:03.155 [localhost-startStop-1] ERROR SecurityLog.com.thingworx.webservices.context.ThreadLocalContext - Failed to retrieve SSOContext
12:31:03.163 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.utils.Log - logLevel set to slf4j
12:31:03.163 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.UrlRewriteFilter - confPath set to /WEB-INF/urlrewrite-rewrite.xml
12:31:03.173 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.Conf - XML builder factory is: com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderFactoryImpl
12:31:03.174 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.Conf - XML Parser: com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl
12:31:03.174 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.Conf - about to parse conf
12:31:03.177 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.ConfHandler - Resolving to DTD /org/tuckey/web/filters/urlrewrite/dtds/urlrewrite4.0.dtd
12:31:03.194 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.Conf - now initialising conf
12:31:03.196 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.Condition - loaded condition header Authorization ^Bearer\s+.*$
12:31:03.196 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.Condition - loaded condition attribute _is_rewritten_ true
12:31:03.201 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.RuleBase - loaded rule rp-url-rewrite (rule 0) (^/(?!rp/.*), /rp/$0 1)
12:31:03.201 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.NormalRule - loaded rule rp-url-rewrite (rule 0) (^/(?!rp/.*), /rp/$0 1)
12:31:03.201 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.Conf - conf status true
12:31:03.201 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.UrlRewriteFilter - inited with 1 rules
12:31:03.201 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.UrlRewriteFilter - conf is ok
12:31:03.201 [localhost-startStop-1] INFO org.tuckey.web.filters.urlrewrite.UrlRewriteFilter - loaded (conf ok)
12:31:03.202 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.UrlRewriteFilter - filter init called
12:31:03.202 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.UrlRewriteFilter - init: calling destroy just in case we are being re-inited uncleanly
12:31:03.202 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.utils.Log - logLevel set to slf4j
12:31:03.202 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.UrlRewriteFilter - confPath set to /WEB-INF/urlrewrite-restore.xml
12:31:03.203 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.Conf - XML builder factory is: com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderFactoryImpl
12:31:03.203 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.Conf - XML Parser: com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl
12:31:03.203 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.Conf - about to parse conf
12:31:03.203 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.ConfHandler - Resolving to DTD /org/tuckey/web/filters/urlrewrite/dtds/urlrewrite4.0.dtd
12:31:03.206 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.Conf - now initialising conf
12:31:03.206 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.RuleBase - loaded rule rp-url-restore (rule 0) (^/rp/(.*)$, /$1 1)
12:31:03.206 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.NormalRule - loaded rule rp-url-restore (rule 0) (^/rp/(.*)$, /$1 1)
12:31:03.206 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.Conf - conf status true
12:31:03.206 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.UrlRewriteFilter - inited with 1 rules
12:31:03.206 [localhost-startStop-1] DEBUG org.tuckey.web.filters.urlrewrite.UrlRewriteFilter - conf is ok
12:31:03.206 [localhost-startStop-1] INFO org.tuckey.web.filters.urlrewrite.UrlRewriteFilter - loaded (conf ok)
12:31:03.269 [localhost-startStop-1] ERROR SecurityLog.com.thingworx.security.authentication.AuthenticationFilter - Could not load session timeout from database, using default: null
12:31:03.282 [localhost-startStop-1] ERROR ErrorLog.com.thingworx.security.authentication.HAAuthenticationFilter - Failed to initialize HA Authentication
12:31:03.284 [localhost-startStop-1] INFO org.tuckey.web.filters.urlrewrite.UrlRewriteFilter - destroy called
Hi
So the error is
hope this helps
Christophe
I deleted keystore.jks from thingworx storage and it works fine for me.I have been struggling for 2 months due to this issue and this made my day...Thank You christophe :D
San
