Hello ,
I was trying to install Thingworx platform postgreSQL 8.0.2 on windows and i downloaded the most recent datecode for the same from the PTC website ,but i got the ThingworxPlatform postgrsql docker instllation setup and not the normal one which we get till thingowrx 7.4 .and as given in the guide of thingworx 8.0 installation we should deploy the war file in the apche tomcat ,where will i get the thingworx.war file for thingworx platform 8.0
Or is PTC provding docker installation only ? if yes where can i find the installation guide and tutorial for the same .
Kind Regards,
Amar
Hi Amar, from where have you downloaded the packages? As far as i can see both are available separately
