Could anyone help me what the below error means? I'm running TW 7
[context: com.thingworx.webservices.context.HttpExecutionContext@73f16e43][message: Thing [DeliveryTable] is not enabled]
I see this in the Application Log as well as Remote Thing Log. I don't have anything that is transmitting as a "DeliveryTable" thing.
Have you had it previously and then deleted? You could try this https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS198580&lang=en_US
Thank you!
That seems to have worked.
