would anyone be able to explain why suddenly the timestamps in the monitor logs show with Arabic numerals. Everything else is in English (as expected) but not the timestamps.
Thanks in advance.
K
Hi, thanks for the quick reply.
I got to the bottom of the issue in the end. It wasn't a date format issue, somehow my user language setting had been set to mr-IN. I've no idea how or even how the language has those characters (Arabic) set. There's nothing in Localisation table that I can see.
Thanks again, issue is now solved for me.
I believe there is a specific localization token for timestamp so I would check that.
