To Retrieve Data from the Thingworx
CK_10001116
How to Retrieve Data from the Thingworx based on the particlar condition(Name).Can you please suggest the query for that..
1 ACCEPTED SOLUTION
Hi @CK_10001116
If you are trying to retrieve data from JSON than follow the given thread:
Data from JSON
If you are using Data table then service like QueryDataTableEntries to retrieve the record.
If these two does not help you. I request you to elaborate more about your use case.
Regards
Bhawna
2 REPLIES 2
Hi @CK_10001116
Data from JSON
Regards
Bhawna
Need Data from Infotable
