Tomcat - This is a proxy server. Does not respond to non-proxy requests.
Sathishkumar_C
We have installed Thingworx 8.5 with Tomcat 8.5. It was working properly. But, after sometime it is showing "This is a proxy server. Does not respond to non-proxy requests." message while trying to open tomcat. What will be the issue? How to resolve?
Thanks & Regards,
Sathishkumar C.
1 ACCEPTED SOLUTION
I have seen in catalina.log the following:
22-Nov-2019 11:24:36.512 SEVERE [main] org.apache.coyote.AbstractProtocol.init Failed to initialize end point associated with ProtocolHandler ["http-nio-8080"]
java.net.BindException: Address already in use: bind
at sun.nio.ch.Net.bind0(Native Method)
at sun.nio.ch.Net.bind(Unknown Source)
at sun.nio.ch.ServerSocketChannelImpl.bind(Unknown Source)
at sun.nio.ch.ServerSocketAdaptor.bind(Unknown Source)
at org.apache.tomcat.util.net.NioEndpoint.bind(NioEndpoint.java:228)
at org.apache.tomcat.util.net.AbstractEndpoint.init(AbstractEndpoint.java:866)
at org.apache.tomcat.util.net.AbstractJsseEndpoint.init(AbstractJsseEndpoint.java:213)
at org.apache.coyote.AbstractProtocol.init(AbstractProtocol.java:575)
at org.apache.coyote.http11.AbstractHttp11Protocol.init(AbstractHttp11Protocol.java:65)
at org.apache.catalina.connector.Connector.initInternal(Connector.java:944)
at org.apache.catalina.util.LifecycleBase.init(LifecycleBase.java:107)
at org.apache.catalina.core.StandardService.initInternal(StandardService.java:549)
at org.apache.catalina.core.StandardServer.initInternal(StandardServer.java:873)
at org.apache.catalina.startup.Catalina.load(Catalina.java:606)
at org.apache.catalina.startup.Catalina.load(Catalina.java:629)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.apache.catalina.startup.Bootstrap.load(Bootstrap.java:311)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:494)
For me this seems that the 8080 port is already used.
Please follow the steps from this article: https://www.ptc.com/en/support/article?n=CS290811
Hope it helps,
Raluca Edu
5 REPLIES 5
aregal01
(To:Sathishkumar_C)
Thank you for your post.  Hopefully we can resolve this issue together.  Did you happen to use a proxy configuration in your config.json file during installation?
Thank you,
Angela
Thanks for your reply.
Installation of tomcat you are asking? Where i can find config.json file?
aregal01
(To:Sathishkumar_C)
I'd actually like to take a step back and get a better idea of the system you're working with.  Can you please provide the following details?
  • Java Version
  • OS (windows, ubuntu, RHEL, Amazon RDS)
  • Persistence (H2, PostgreSQL, DSE, Azure, etc)
  • Where exactly are you seeing the error message?  (Is it in a Tomcat log?)
  • Do you have any error logs to share?
  • Have you successfully launched ThingWorx platform and created and saved an Entity?
Thank you,
Angela
Please find details below,
  • Java 1.8.0_171
  • Windows 10 Home
  • PostgreSQL 9.4 Thingworx
  • PostgreSQL 9.6 for Streams (Persistance Provider)
Both the servers installed on same system.
Thanks.
Hope it helps,
Raluca Edu
