Totaling valuestream - JSON does not allow non-finite numbers problem
DavorGranic
I`m going trough  valuestream entries and filtering them and saving to infotable in a service.
Basicaly im totalling values between hour A to hour B on each day for a week.
Problem is I get error when i use:
Totall+= StreamValue;
Im getting error:
"Wrapped org.json.JSONException: JSON does not allow non-finite numbers. Cause: JSON does not allow non-finite numbers."
everythign works fine if I use Totall+=1 or Totall= StreamValue;  but  +=StreamValue makes a problem.
Code used:
var params = {
                oldestFirst: undefined /* BOOLEAN */,
                maxItems: undefined /* NUMBER */,
                endDate: undefined /* DATETIME */,
                query: undefined /* QUERY */,
                startDate: undefined /* DATETIME */
var data = me.QueryPropertyHistory(params);
var params = {
                infoTableName : "InfoTable",
                dataShapeName : "StorageDataShape_granicd"
var result = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
var tableLength = data.rows.length;
var newEntry = new Object();
var Once=0;
for (var y = 0; y < 7; y++)
        var Type1=0;
        Once=0;
        newEntry.timestamp=null;
        for (var x = 0; x < tableLength; x++)
            var row=data.getRow(x);
            if(row.timestamp.getDay()===y && row.timestamp.getHours() >= FromHour && row.timestamp.getHours() < TillHour) //row.timestamp.getDay()==y
                if(Once==0)
                    newEntry.timestamp=row.timestamp;
                    Once=1;
                Type1+= row.LM;      //problem line
       newEntry.LM_Totall=Type1;
       result.AddRow(newEntry);
me.Totallhours=result;
Turns out problem was some properties in stream were NaN like error said(tho it refered to non-finite). I just needed to check in code first if they are NaN/empty then try to add them if they are not. :/ Best way is "if(x!=x)"  x - some property value.
3 REPLIES 3
sbalta
(To:DavorGranic)
Hello @DavorGranic,
Not sure exactly where the problem in the code could be, but I was thinking that this article might help:
https://www.ptc.com/en/support/article?n=CS267063 (refering to JSON not allowing non-finite numbers)
slangley
23-Emerald II
(To:DavorGranic)
Hi @DavorGranic.
If you are satisfied with the solution you posted, please mark it as the Accepted Solution for the benefit of others with the same question.
Thank you for using our Community!
--Sharon
