I created a remotething in new composer by binding tag from kepservex,and added a anomly alert, then I go to mashup Anomaly_Dashboard to monitoring my newly created thing, but it always failed of training.
Here is error log:
2017-08-08 12:32:58.757+0800 [L: ERROR] [O: S.c.t.d.e.DSLProcessor] [I: ] [U: Administrator] [S: ] [T: http-nio-80-exec-12] Execution error in service script [AnomalyServices GetAnomalyAlertsByEntity] : TypeError: Cannot call method "GetPropertyDefinitions" of null
Error in invoking service Things_AnomalyServices1, GetAnomalyAlertAttributes, Things, AnomalyServices, Services, GetAnomalyAlertAttributes. Error from the server: "EOF"
Returning a FAILED state for TimedValue [timestamp=1502168642040, value=95.0]. ThingWatcherMessage [timestamp=2017-08-08T13:04:02.508, severity=ERROR, state=ThingWatcherInternalState [internal=OBTAINING_MODEL, external=TRAINING], messageCode=WAT1001E, messageText=Operation exception. {Throwable=[Trainer.TrainingJobErrorException: Training job with id 39 entered into an incomplete state [FAILED] unable to process models. Error message: [ConnectException: Connection refused: connect]}]]
Anomaly Alert [Thing4Anomaly2-Simulation_Examples_Functions_Ramp1-amomalydemo2] Failed when in [TRAINING] State. Thingwatcher Error Code :: [WAT1001E] Message :: Operation exception. {Throwable=[Trainer.TrainingJobErrorException: Training job with id 39 entered into an incomplete state [FAILED] unable to process models. Error message: [ConnectException: Connection refused: connect]}]
Unable to persist entries because ForsetiClient[id=15785,tx=Transaction[eventId=26137,thread=1369:'ForkJoinPool-34-worker-12',status=STATUS_ACTIVE,resourceCount=1]] can't acquire ExclusiveLock{owner=ForsetiClient[id=15794,tx=Transaction[eventId=26145,thread=1444:'ForkJoinPool-34-worker-30',status=STATUS_ACTIVE,resourceCount=1]]} on NODE(5602), because holders of that lock are waiting for ForsetiClient[id=15785,tx=Transaction[eventId=26137,thread=1369:'ForkJoinPool-34-worker-12',status=STATUS_ACTIVE,resourceCount=1]]._ Wait list:ExclusiveLock[ForsetiClient[id=15794,tx=Transaction[eventId=26145,thread=1444:'ForkJoinPool-34-worker-30',status=STATUS_ACTIVE,resourceCount=1]] waits for [15785, 15793, 15794, ]]
Error occurred during commit for the ThingworxPersistenceProvider persistence provider.
Anyone can help? Thanks a lot.
Hello, Tom.
We found some internal documentation which suggest trying the following:
Can you try this and let us know the results?
-- Craig A.
Hi Craig,
Thanks for your help, here is my configruation of microservices.properties
dataset.webservices.url=
dataset.app.id=
dataset.app.key=
results.destination.uri=results://192.168.31.202:8090/results/models
file.storage.path=tempStorage
I can access http://192.168.31.202:8090/results/models in browser at Thingworx server. And I already restart Tomcat of Thingworx, and restart the training and results microservices. Then using RestartAnomalyAlert service to retrain,but I got the same error. I doubt something wrong with my database.
It seems I can't use DisableAlertsForProperty or EnableAlertsForProperty services in AnomalyServices, because it doesn't accept parameter of thing name. Also I can't use service of RetrainAnomalyAlert, it says:
JavaException: com.thingworx.common.exceptions.InvalidRequestException: Attempted to retrain ThingWatcher [Thing4Anomaly2-Simulation_Examples_Functions_Ramp1-amomalydemo2] that is in an unsupported state [FAILED] (RetrainAnomalyAlert#38)
Thanks & Best Regards
Tom
Hi Tom
Could you provide some more details as below:
- are you deploying the microservices as docker or jar file ?
- could you provide the full command you execute to start the microservices or docker run command
- could you send a screenshot of AlertProcessingSubsytem > Configuration page
- are ThingWorx and microservices on the same machine or different ?
- what is the OS of ThingWorx server and microservices server ?
Could you uplaod:
- ThingWorxStorage/logs/ApplicationLog.log
- Tomcat/logs from ThingWorx machine
Note to reset the alert you can maybe try the disableAllAlert and EnableAllAlert service instead for the time being.
Christophe
Hi Christophe,
Thanks for your help. I believe my configuration is correct. Because the monitoring once working properly. And I just tried restart VMware(Thingworx installed in VMware), it is working again,don't know why.Although I still got the error messages which I putted in my original post. At least I can say those error dose not affect anomaly detection.
Tom
