I currently have a url: http://172.20.100.3/cgi-bin/json.cgi?json={"method": "broadcaston", "params": [1], "id": 10}
This is for lighting control, and the json controls what happens with the lights and returns a json when you go to the web page. I am currently using the GetJson snippet and passing in the json.
var Mycontent = {
"method" : "broadcastoff",
"params" : "[1]",
"id" : "30"
var params = {
url: "http://172.20.100.3/cgi-bin/json.cgi?json=",
content: Mycontent,
var result = Resources["ContentLoaderFunctions"].GetJSON(params);
All that is being returned is - {"headers":""}
Any help with where I'm going wrong would be greatly appreciated.
The solution is to encapsulate the whole link as a string and use %7b instead of {.
And use %7d instead of }.
What all have you tried so far with the parameters?
Can you try to create the json but 'encapsulated' as a string does that make any difference?
also for the return, instead of doing getjson, try gettext first and see if anything at all is returned.
All I am passing into the parameters is the url, and sometimes the content depending on what I'm trying.
When I try to encapsulate the JSON I got the error -
"Error executing service LightTest. Message :: Illegal character in opaque part at index 40: http:172.20.100.3/cgi-bin/json.cgi?json={"method":"broadcastoff","params":"[1]","id":"30"} - See Script Error Log for more details."
That is with both getJSON and getText.
