I used the twilio extension quite a while ago.
I tried to use it again later, but I get an error.
I used to remember that I had tested a text message by allowing a country code.
Not now.
Has anybody ever experienced the same error as me?
Also, caller ID used Verified Caller IDs on the homepage.
thank
If someone is experiencing the same symptoms as me, try the following:
This is the case if the account you used previously is a trial account.
Delete the existing AppKey
And get the trial number again while registering the new AppKey
It then works normally.
If someone is experiencing the same symptoms as me, try it
Thank you.
Thank you.
