UI Automated Testing out of the box
TanmeyTWX
Hi Folks,
Is there any out of the box Automated testing for Thingworx UI/ Mashup?
As far as I know there is no such OOTB feature but wanted to confirm if PTC has come up with this feature lately.
Also, please suggest some solution in case need to develop custom automated testing of Thingworx UI. may be using other applications like selenium, cucumber, etc.
Note: I have 40+ mashups application, so can't accommodate any complex customization as its going to take lot of effort.
Thanks in advance.
1 ACCEPTED SOLUTION
abjain
(To:TanmeyTWX)
@TanmeyTWX As of now there is no OOTB solution for automated testing in thingworx. You can read the following community post for it : https://community.ptc.com/t5/IoT-Tech-Tips/How-can-ThingWorx-play-an-active-role-in-my-team-s-DevOps/td-p/613328
abjain
(To:TanmeyTWX)
slangley
23-Emerald II
(To:TanmeyTWX)
Hi @TanmeyTWX
If you feel your question has been answered, please mark the previous response as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
geva
(To:TanmeyTWX)
You should also check out the 4-5 part series in IoT Tech Tips on JMeter as it focuses on using JMeter to do load and performance testing of Mashups.
