I'm trying, from a service, to run this code:
var params = {
containerUfid: undefined /* STRING */,
criteria: "name=32344444" /* STRING */,
type: "wt.part.WTPart" /* STRING */,
dataShape: demo.wt.part.WTPart" /* DATASHAPENAME */
};// result: INFOTABLE
var Result = Things["ptc-windchill-demo-thing"].Query(params);
The error message I receive is: "Unable To Convert From org.mozilla.javascript.UniqueTag to INFOTABLE".
I defined as service's output
base type: INFOTABLE
data shape: demo.wt.part.WTPart
What am I doing wrong ?
Change Result to use a lower case r, this should resolve the issue.
Thanks !
