Unable to connect ThingWorx 8.3.0-b349 to MS SQL external Database. I use the extension pointed by the various tutorials about, then I create a thing using the ThingTemplate MsSQL server. I've tried to change different parameters for the configuration tab. In the application log i receive the messages :
[message: Entity Not Found : [JdbcCreator]]
[message: Entity Not Found : [MySqlServer]] (note that I use the Template and parameters for Ms SQl not MySql)
[message: Unable To Convert From java.lang.String to NUMBER]
I verified that in the Tomcat folder lib there is the MsSql.jar file.
I used a similar procedure for Postgres Database and works, but I keep failing with MsSql.
Hi @darcudarcu
I found these 2 articles which might be helpful, please check.
1.CS297147
2. CS295944
Vibhuti
Hi @darcudarcu
You may refer this community post External-database-connection-guide-for-ThingWorx-v8 for more information.
Also, please check these two articles.
Vibhuti
I can connect now.
However, in my DataBase I have two tables, I can query one table successfully but querying the other one gives me the error : Connection Closed.
Commands not related to a specific table (such as getdate()) work. The query is corrected because is tested and copied and pasted from the database.
The two tables have the same connection properties.
Thanks for letting know that the connection issue is resolved.
Could you please provide the exact error/screenshot about the querying error?
This is the error, note that querying another table of the same database it works fine.
Hi @darcudarcu
1.CS297147
2. CS295944
Vibhuti
Hi @vangne ,
the connection to the database works, the property "isConnected" is TRUE and the default line "GETDATE()" works. Also the query for "Table1" works, but I receive the error only with "Table2" belonging to the same database.
Hi @vangne ,
the problem was linked to a column data type not supported by thingworx ("sql_variant" for MS SQL).
To solve this problem I had to cast the value into a FLOAT.
Thanks for the support.
