I am trying to update a stream entry with a user who is not Administrator but I get this error:
"Unable to Invoke Service UpdateStreamEntry on DefaultAlertStream : null"
When I am Administrator it works fine.
Version used:
ThingWorx 7.4.0-b159
I have the same config (scritp, visibility, etc) using version TW 7.3.3 and i don't have error.
Thanks.
Usually that error means you don't have visibility to the entity you are invoking the service on.
I would double check visibility. in 8.x they remove users from the Everyone org by default for example.
Also remember to check the Persistence Provider visibility
it works!. I forgot to set the visibility of Persistence Provider.
Thanks Pai.
