#include <DHT_U.h>
#include <SPI.h>
#include <Ethernet.h>
#define propertyCount 2
#define DHTPIN 2 // what digital pin we're connected to
#define DHTTYPE DHT11
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
char server[] = "https://academic.cloud.thingworx.com/Thingworx/Things/salesforceThing_ahmed123/Properties/Temperature";
EthernetClient client;
char appKey[] = "03bbedef-bb57-4ec1-9cad-8126d72d2e75";
char thingName[] = "salesforceThing_ahmed123";
int timeBetweenRefresh = 5000;
char serviceName[] = "setTempAndHumid";
char* propertyNames[] = {"Temp", "Humid"};
double propertyValues[propertyCount];
unsigned long lastConnectionTime = 0;
boolean lastConnected = false;
DHT dht(DHTPIN, DHTTYPE);
I'm getting this response in arduino uno serial monitor,
could you please guide me with proper instruction where I'm I getting wrong.
DHT22 Library Demo
Trying to get an IP address using DHCP
My IP address: 192.168.0.38
Humidity: 27.00 % Temperature: 30.00 *C 86.00 *F Heat index: 28.55 *C 83.40 *F
connected
POST /Thingworx/Things/salesforceThing_ahmed123/Services/setTempAndHumid?appKey=03bbedef-bb57-4ec1-9cad-8126d72d2e75&method=post&x-thingworx-session=true<&Temp=30.00&Humid=27.00> HTTP/1.1
Host: https://academic.cloud.thingworx.com/Thingworx/Things/salesforceThing_ahmed123/Properties/Temperature
Content-Type: text/html
Humidity: 28.00 % Temperature: 30.00 *C 86.00 *F Heat index: 28.62 *C 83.51 *F
connected
POST /Thingworx/Things/salesforceThing_ahmed123/Services/setTempAndHumid?appKey=03bbedef-bb57-4ec1-9cad-8126d72d2e75&method=post&x-thingworx-session=true<&Temp=30.00&Humid=28.00> HTTP/1.1
https://academic.cloud.thingworx.com/Thingworx/Things/salesforceThing_ahmed123/Services/setTempAndHumid?appKey=putAppKeyHere&method=post&x-thingworx-session=true&Temp=30.00&Humid=28.00
Remove the <> brackets and the post url will work. Also, I would not post clear text appKeys. Anyone can gain access to your instance with them.
Adam
Hello Adam,
Thanks for reply,
I made changes as you mention above, but still I'm not seeing thingworx property values updates, is somewhere else I'm doing wrong?
DHT22 Library Demo
Humidity: 22.00 % Temperature: 29.00 *C 84.20 *F Heat index: 27.52 *C 81.53 *F
connected
POST /Thingworx/Things/salesforceThing_ahmed123/Services/setTempAndHumid?appKey=03bbedef-bb57-4ec1-9cad-8126d72d2e75&method=post&x-thingworx-session=true&Temperature=29.00&Humidity=22.00 HTTP/1.1
Host: https://academic.cloud.thingworx.com/Thingworx/Things/salesforceThing_ahmed123/Services/setTempAndHumid?appKey=03bbedef-bb57-4ec1-9cad-8126d72d2e75&method=post&x-thingworx-session=true&Temperature=30.00&Humidity=28.00
I'm very thankful to you if this get resolve.
Ahmed
