Unable to connect remote thing to thingworkx
rshukla-2
7-Bedrock
I'm trying to connect my Intel Galileo Gen 2 board to thingworkx. I'm following the tutorial  Weather Application with Intel Galileo | ThingWorx  . In the example, they have used the HTU21D sensor . As it wasn't available where I live, I'm performing the tutorial  using  a BMP180 sensor. I'm using it to sense temperature and pressure.
I have modified the code given for HTU21D , as follow for BMP180:
Note: For security reasons in have modified my API KEY and MAC address.
include <twApi.h>
#include <twLogger.h>
#include <twOSPort.h>
#include <SFE_BMP180.h>
#include <Ethernet.h>
#include <stdio.h>
#include <string.h>
#include <Wire.h>
SFE_BMP180 tp;
/* Mac address of the network adapter */
byte mac[] = {0x98, 0x4F, 0xEE, 0x01, 0xCB, 0xE9  };
/* Name of your thing */
char * thingName = "myTestTempPress";
/* IP/hostname of your TWX server */
char * serverName = "mitpune66.cloud.thingworx.com";
/* port */
int port = 443;
/* API key */
char * apiKey = "d9c81d35-5a28-49b0-9ddf-e9193eda3b66";
/* refresh rate */
int timeBetweenRefresh = 1000;
/* Hold all the properties */
struct  {
  double Temperature;
  double Pressure;
properties;
  void sendPropertyUpdate() {
  /* Create the property list */
propertyList * proplist = twApi_CreatePropertyList("Temperature",twPrimitive_CreateFromNumber(properties.Temperature), 0);
  if (!proplist) {
  TW_LOG(TW_ERROR,"sendPropertyUpdate: Error allocating property list");
  return;
  twApi_AddPropertyToList(proplist,"Pressure",twPrimitive_CreateFromNumber(properties.Pressure), 0);
  twApi_PushProperties(TW_THING, thingName, proplist, -1, FALSE);
  twApi_DeletePropertyList(proplist);
void dataCollectionTask()
  char status;
  status = tp.startTemperature();
  status = tp.getTemperature(properties.Temperature);
  status = tp.startPressure(3);
  status = tp.getPressure(properties.Pressure, properties.Temperature);
    Serial.print("Time:");
  Serial.print(millis());
  Serial.print(" Temperature:");
  Serial.print(properties.Temperature, 1);
  Serial.print("C");
  Serial.print(" Pressure:");
  Serial.print(properties.Pressure, 1);
  Serial.print("mb");
  Serial.println();
  /* Update the properties on the server */
  sendPropertyUpdate();
* Property Handler Callbacks
enum msgCodeEnum propertyHandler(const char * entityName, const char * propertyName,  twInfoTable ** value, char isWrite, void * userdata) {
  char * asterisk = "*";
  if (!propertyName) propertyName = asterisk;
  TW_LOG(TW_TRACE,"propertyHandler - Function called for Entity %s, Property %s", entityName, propertyName);
  if (value) {
      /* Property Reads */
      if (strcmp(propertyName, "Temperature") == 0) *value = twInfoTable_CreateFromNumber(propertyName, properties.Temperature);
      else if (strcmp(propertyName, "Pressure") == 0) *value = twInfoTable_CreateFromNumber(propertyName, properties.Pressure);
      else return TWX_NOT_FOUND;
    return TWX_SUCCESS;
  else {
    TW_LOG(TW_ERROR,"propertyHandler - NULL pointer for value");
    return TWX_BAD_REQUEST;
void setup() {
  int err=0;
  /* Open serial connection */
  Serial.begin(9600);
  /* Wait for someone to launch the console */
  delay(3000);
  /* Setup the ethernet connection */
  Serial.println("Attempting to start Ethernet2");
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
  else {
    Serial.println("Sucess getting dhcp address");
  /* start adapter */
  system("ifup eth0");
  /* wait for it to start */
  delay(1000);
  Serial.print("Galileo IP address: ");
  Serial.println(Ethernet.localIP());
  system("telnetd -l /bin/sh");
  Serial.println("BMP180 Example!");
  tp.begin();
  Serial.print("Initialize TWX: ");
  err = twApi_Initialize(serverName, port, TW_URI, apiKey, NULL, MESSAGE_CHUNK_SIZE, MESSAGE_CHUNK_SIZE, TRUE);
  if (err) {
    Serial.println("Error initializing the API");
  /* Allow self signed certs */
  twApi_SetSelfSignedOk();
  /* Regsiter our properties */
   twApi_RegisterProperty(TW_THING, thingName, "Temperature", TW_NUMBER, NULL, "ALWAYS", 0, propertyHandler,NULL);
   twApi_RegisterProperty(TW_THING, thingName, "Pressure", TW_NUMBER, NULL, "ALWAYS", 0, propertyHandler,NULL);
  /* Bind our thing */
  twApi_BindThing(thingName);
  /* Connect to server */
  if (!twApi_Connect(CONNECT_TIMEOUT, CONNECT_RETRIES)) {
    Serial.println("sucessefully connected to TWX!");
void loop() {
  // put your main code here, to run repeatedly:
  dataCollectionTask();
  delay(timeBetweenRefresh);
  Serial.print(".");
Every time when I burn the code to my board  the serial monitor waits for a while after printing "Initialize TWX:" and then start printing the temperature and pressure 0 without giving any information regarding the connection! ( In tutorial they have shown a message"successfully connected to TWX!"  when device is connected ) I have attached the screenshot of Serial Monitor and the original as well as modified code .
Please let me know where I'm going wrong  and quick response to this issue will be really appreciated as I have to give a demo to my fellow classmates on the day after tomorrow on IOT and ThingWorx.
0 REPLIES 0
