Unable to run azure-iot.bat in windows to start connection server during IoT Hub Connector launch
23:22:55.039 [NettyClient-NIO-5] INFO c.t.s.i.p.v1.V1ProtocolContext - Preparing new Connection Authentication Request for channel: com.thingworx.sdk.impl.transport.MuxingBytesChannel$AuthTrackingBytesChannel@2ac59f79, request: V1AuthMessage [header=V1MessageHeader [messageType=20, requestId=1, endpointId=-1, sessionId=-1, isMultiPart=0], securityClaims=toString() called on SecurityClaims. No output emitted as this could be a security issue. If you want to log information you must explicitly do so at your own risk. It is NOT recommended you do so.]
23:22:55.057 [NettyClient-NIO-5] ERROR c.t.s.i.transport.MuxingBytesChannel - Error refilling connections on [channel: null, endpoint ws://localhost:8080/Thingworx/WS, uri: ws://localhost:8080/Thingworx/WS] failed : Connection authentication/registration FAILED [channel: com.thingworx.sdk.impl.transport.MuxingBytesChannel$AuthTrackingBytesChannel@2ac59f79, code: STATUS_UNAUTHORIZED, reason: Error [context: authenticating connection][cause: Missing application key!]]
com.thingworx.sdk.api.exception.AuthenticationException: Connection authentication/registration FAILED [channel: com.thingworx.sdk.impl.transport.MuxingBytesChannel$AuthTrackingBytesChannel@2ac59f79, code: STATUS_UNAUTHORIZED, reason: Error [context: authenticating connection][cause: Missing application key!]]
at com.thingworx.sdk.impl.protocol.common.AbstractProtocolContext$AuthChannelListenerAdapter.messageReceived(AbstractProtocolContext.java:225)
at com.thingworx.sdk.impl.protocol.common.AbstractProtocolContext$AuthChannelListenerAdapter.messageReceived(AbstractProtocolContext.java:174)
at com.thingworx.sdk.impl.transport.netty.NettyBytesChannel.messageReceived(NettyBytesChannel.java:112)
at com.thingworx.sdk.impl.transport.netty.NettyChannelHandler.channelRead0(NettyChannelHandler.java:125)
at com.thingworx.sdk.impl.transport.netty.NettyChannelHandler.channelRead0(NettyChannelHandler.java:26)
at io.netty.channel.SimpleChannelInboundHandler.channelRead(SimpleChannelInboundHandler.java:105)
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:318)
at io.netty.channel.AbstractChannelHandlerContext.fireChannelRead(AbstractChannelHandlerContext.java:304)
at io.netty.handler.timeout.IdleStateHandler.channelRead(IdleStateHandler.java:266)
at io.netty.handler.codec.MessageToMessageDecoder.channelRead(MessageToMessageDecoder.java:103)
at io.netty.handler.codec.ByteToMessageDecoder.fireChannelRead(ByteToMessageDecoder.java:276)
at io.netty.handler.codec.ByteToMessageDecoder.channelRead(ByteToMessageDecoder.java:263)
at io.netty.channel.DefaultChannelPipeline.fireChannelRead(DefaultChannelPipeline.java:846)
at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:131)
at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:511)
at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:468)
at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:382)
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:354)
at io.netty.util.concurrent.SingleThreadEventExecutor$2.run(SingleThreadEventExecutor.java:112)
at java.lang.Thread.run(Thread.java:748)
The appKey and Thingworx URL are as mentioned:-
transport.websockets {
// ThingWorx platform application key
app-key = "*******************************"
// One or more platforms can be specified here, comma separated
platforms = "ws://localhost:8080/Thingworx/WS"
ThingWorx Version-8.4.4
IoT Hub Connector version- 2.0.0.141
Thanks in advance.
