I create the Data Shape, with the 3 fields.
When I want to save it an error message says :
save failed, status: error message: Unable To Convert From org.json.JSONObject$Null to NUMBER
Any idea where this comes from ?
Thank you,
Hi Sushant,
I figured it out. The Admin user had the data shape open as well. After it was closed, I could save the edits to the datashape. Thank you for your help.
Hi Wendy, how was this DataShape created? Which persistence provider are you working with? Was there any more information in the Application logs?
Hi Sushant,
Thanks Wendy for confirming.
