Upgrading Inlfuxdb 1.8.10 to 2.7.5 on thingworx 9.3 - Unable to query or view data
NiKlaus
Hi there,
I am looking for a solution on the upgrade process regarding inlfuxdb and thingworx.
I managed to successfully upgrade influxdb from version 1.8.10 to 2.7.5 and I am able to succesfully connect a new persistence provider to thingworx.
Not able to see an of the data that is present in the data base.
On the influxdbV2 frontend hosted on port 8086, I am able to view the historic data, so i know i haven't lost the data. It's bucket name appeared a thingworx/autogen, so i renamed it to thingworx as that was the settings in the persistant provider.
When we do a query named property history, we get an error with code : 2006
Any help or assistance would be appreciated.
Hi @NiKlaus  check the DB user permission, and look at the below article.
https://www.ptc.com/en/support/article/CS239982
5 REPLIES 5
Hi, @NiKlaus   Can you share the Thingworx and DB logs?
Hi @Surya_Tiwari , which logs from thingworx?
Here is the configuration log file:
2024-03-04 11:37:15.491+0000 [L: INFO] [O: Import] [I: END_BLOCK_CHANGE] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-4] action = END_BLOCK_CHANGE
2024-03-04 11:37:20.150+0000 [L: INFO] [O: Import] [I: BEGIN_BLOCK_CHANGE] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-2] action = BEGIN_BLOCK_CHANGE
2024-03-04 11:37:20.150+0000 [L: INFO] [O: Import] [I: END_BLOCK_CHANGE] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-2] action = END_BLOCK_CHANGE
root@ubuntu:/ThingworxStorage/logs# tail -100 ConfigurationLog.log
2024-03-04 11:34:22.288+0000 [L: INFO] [O: Import] [I: END_BLOCK_CHANGE] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-4] action = END_BLOCK_CHANGE
2024-03-04 11:35:34.341+0000 [L: INFO] [O: Import] [I: END_BLOCK_CHANGE] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-7] action = END_BLOCK_CHANGE
2024-03-04 11:35:41.537+0000 [L: INFO] [O: Import] [I: BEGIN_BLOCK_CHANGE] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-6] action = BEGIN_BLOCK_CHANGE
2024-03-04 11:35:41.537+0000 [L: INFO] [O: PersistenceProvider] [I: InfluxDB2] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-6] action = CREATE, reason = header : name : updated, projectName : updated, persistenceProviderPackage : updated, isDefault : updated, enabled : updated_
2024-03-04 11:35:41.537+0000 [L: INFO] [O: Import] [I: END_BLOCK_CHANGE] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-6] action = END_BLOCK_CHANGE
2024-03-04 11:36:09.258+0000 [L: INFO] [O: Import] [I: BEGIN_BLOCK_CHANGE] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-6] action = BEGIN_BLOCK_CHANGE
2024-03-04 11:36:09.258+0000 [L: INFO] [O: PersistenceProvider] [I: InfluxDB2] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-6] action = MODIFY, reason = configuration : orgName : updated, bucketName : updated, token : updated_
2024-03-04 11:36:09.258+0000 [L: INFO] [O: Import] [I: END_BLOCK_CHANGE] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-6] action = END_BLOCK_CHANGE
2024-03-04 11:36:19.068+0000 [L: INFO] [O: Import] [I: BEGIN_BLOCK_CHANGE] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-6] action = BEGIN_BLOCK_CHANGE
2024-03-04 11:36:19.068+0000 [L: INFO] [O: PersistenceProvider] [I: InfluxDB2] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-6] action = MODIFY, reason = header : enabled : updated_
2024-03-04 11:36:19.068+0000 [L: INFO] [O: Import] [I: END_BLOCK_CHANGE] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-6] action = END_BLOCK_CHANGE
2024-03-04 11:36:24.737+0000 [L: INFO] [O: Import] [I: BEGIN_BLOCK_CHANGE] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-7] action = BEGIN_BLOCK_CHANGE
Here is the influx upgrade log:
{"level":"info","ts":1709549032.323138,"caller":"upgrade/setup.go:73","msg":"CLI config has been stored.","path":"/root/.influxdbv2/configs"}
{"level":"info","ts":1709549032.3232183,"caller":"upgrade/database.go:202","msg":"Checking available disk space"}
{"level":"info","ts":1709549032.3258162,"caller":"upgrade/database.go:223","msg":"Computed disk space","free":"722 GB","required":"3.3 GB"}
{"level":"info","ts":1709549105.738603,"caller":"upgrade/database.go:51","msg":"Upgrading databases"}
{"level":"info","ts":1709549107.4220204,"caller":"upgrade/database.go:101","msg":"Creating mapping","database":"thingworx","retention policy":"autogen","orgID":"xxxxxxx","bucketID":"xxxxxx"}
{"level":"info","ts":1709549330.8308513,"caller":"upgrade/database.go:195","msg":"Database upgrade complete","upgraded_count":1}
{"level":"info","ts":1709549330.831032,"caller":"upgrade/security.go:45","msg":"Upgrading 1.x users"}
{"level":"warn","ts":1709549330.831069,"caller":"upgrade/security.go:50","msg":"User is admin and will not be upgraded","username":"xxxx"}
{"level":"info","ts":1709549330.8311048,"caller":"upgrade/security.go:115","msg":"User upgrade complete","upgraded_count":0}
{"level":"info","ts":1709549330.831132,"caller":"upgrade/upgrade.go:488","msg":"Upgrade successfully completed. Start the influxd service now, then log in","login_url":"http://localhost:8086"}
Hi, @NiKlaus  Can you share the application and error logs?
Hi @Surya_Tiwari
Error logs:
2024-03-04 11:49:00.120+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-8] Execution error in service script [getCustomKibbleData] :: com.thingworx.common.exceptions.DataAccessException: [1,018] Data store unknown error: [Error occurred while accessing the data provider.]
2024-03-04 11:49:02.703+0000 [L: ERROR] [O: E.c.t.p.i.InfluxdbDataExceptionTranslator] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-9] null
2024-03-04 11:49:02.703+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-9] [1,018] Data store unknown error: [Error occurred while accessing the data provider.]
2024-03-04 11:49:02.707+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-9] Execution error in service script [getCustomKibbleData] :: com.thingworx.common.exceptions.DataAccessException: [1,018] Data store unknown error: [Error occurred while accessing the data provider.]
2024-03-04 12:31:22.472+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: SuperUser] [S: ] [P: ] [T: pool-23-thread-1] Error collecting metrics for ValueStreamProcessingSubsystem
2024-03-04 12:31:22.472+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: SuperUser] [S: ] [P: ] [T: pool-23-thread-1] Error collecting metrics for StreamProcessingSubsystem
2024-03-04 12:31:40.154+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: ] [S: ] [P: ] [T: ClientProcessor-1] Could not send response message. APIRequestMessage [requestId: 317353, endpointId: -1, sessionId: -1, method: POST, entityName: SPARX_271653_THINGWORX_RemoteThing_0df63db8-8c77-4960-8e2f-ef46fde4f3b5, characteristic: Services, target: NotifyPropertyUpdate]
2024-03-04 12:53:00.128+0000 [L: ERROR] [O: E.c.t.p.i.InfluxdbDataExceptionTranslator] [I: ] [U: Administrator] [S: ] [P: ] [T: TWEventProcessor-6] null
2024-03-04 12:53:00.128+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: Administrator] [S: ] [P: ] [T: TWEventProcessor-6] [1,018] Data store unknown error: [Error occurred while accessing the data provider.]
2024-03-04 12:53:00.161+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: Administrator] [S: ] [P: ] [T: TWEventProcessor-6] Error Executing Event Handler 'UpdateFaultReportStream' for event Type.Thing:Entity.FaultReportUpdate_Scheduler:Event.ScheduledEvent
root@ubuntu:/ThingworxStorage/logs# tail -100 ErrorLog.log
2024-03-04 10:31:22.256+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: SuperUser] [S: ] [P: ] [T: pool-9-thread-1] [2,002] No connection. Contact the administrator.
2024-03-04 10:31:22.261+0000 [L: ERROR] [O: E.c.t.p.i.InfluxdbDataExceptionTranslator] [I: ] [U: SuperUser] [S: ] [P: ] [T: pool-9-thread-1] java.net.ConnectException: Failed to connect to localhost/127.0.0.1:8086
2024-03-04 10:31:22.261+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: SuperUser] [S: ] [P: ] [T: pool-9-thread-1] [2,002] No connection. Contact the administrator.
2024-03-04 10:31:22.262+0000 [L: ERROR] [O: E.c.t.p.i.InfluxdbDataExceptionTranslator] [I: ] [U: SuperUser] [S: ] [P: ] [T: pool-9-thread-1] java.net.ConnectException: Failed to connect to localhost/127.0.0.1:8086
2024-03-04 10:31:22.262+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: SuperUser] [S: ] [P: ] [T: pool-9-thread-1] [2,002] No connection. Contact the administrator.
2024-03-04 10:31:22.263+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: SuperUser] [S: ] [P: ] [T: pool-9-thread-1] Unable to write entry in stream [TestWeather_VS] [com.thingworx.common.exceptions.DataAccessException: [2,002] No connection. Contact the administrator.]
2024-03-04 11:10:54.120+0000 [L: ERROR] [O: E.c.t.p.i.InfluxdbDataExceptionTranslator] [I: ] [U: SuperUser] [S: ] [P: ] [T: pool-9-thread-1] java.lang.ClassCastException: class org.msgpack.value.impl.ImmutableLongValueImpl cannot be cast to class org.msgpack.value.ImmutableMapValue (org.msgpack.value.impl.ImmutableLongValueImpl and org.msgpack.value.ImmutableMapValue are in unnamed module of loader org.apache.catalina.loader.ParallelWebappClassLoader @24e8de5c)
2024-03-04 11:10:54.120+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: SuperUser] [S: ] [P: ] [T: pool-9-thread-1] [2,006] Unknown error occurred. Contact the administrator if this re-occurs.
2024-03-04 11:10:54.121+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: SuperUser] [S: ] [P: ] [T: pool-9-thread-1] Unable to write entry in stream [1WorxAuditTools.VS] [com.thingworx.common.exceptions.DataAccessException: [2,006] Unknown error occurred. Contact the administrator if this re-occurs.]
2024-03-04 11:11:08.873+0000 [L: ERROR] [O: E.c.t.p.i.InfluxdbDataExceptionTranslator] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-2] {"code":"unauthorized","message":"Unauthorized"}
2024-03-04 11:11:08.873+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-2] [1,018] Data store unknown error: [Error occurred while accessing the data provider.]
2024-03-04 11:11:08.933+0000 [L: ERROR] [O: E.c.t.p.i.InfluxdbDataExceptionTranslator] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-8] {"code":"unauthorized","message":"Unauthorized"}
2024-03-04 11:11:08.933+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-8] [1,018] Data store unknown error: [Error occurred while accessing the data provider.]
2024-03-04 11:11:08.936+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-8] Execution error in service script [ActionCam1] :: com.thingworx.common.exceptions.DataAccessException: [1,018] Data store unknown error: [Error occurred while accessing the data provider.]
2024-03-04 11:11:08.984+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-2] Execution error in service script [ActionCam1] :: com.thingworx.common.exceptions.DataAccessException: [1,018] Data store unknown error: [Error occurred while accessing the data provider.]
2024-03-04 11:11:09.060+0000 [L: ERROR] [O: E.c.t.p.i.InfluxdbDataExceptionTranslator] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-9] java.lang.ClassCastException: class org.msgpack.value.impl.ImmutableLongValueImpl cannot be cast to class org.msgpack.value.ImmutableMapValue (org.msgpack.value.impl.ImmutableLongValueImpl and org.msgpack.value.ImmutableMapValue are in unnamed module of loader org.apache.catalina.loader.ParallelWebappClassLoader @24e8de5c)
2024-03-04 11:11:09.060+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-9] [2,006] Unknown error occurred. Contact the administrator if this re-occurs.
2024-03-04 11:11:09.063+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-9] Execution error in service script [getKibbleShaftDepthData] :: com.thingworx.common.exceptions.DataAccessException: [2,006] Unknown error occurred. Contact the administrator if this re-occurs.
2024-03-04 11:11:09.311+0000 [L: ERROR] [O: E.c.t.p.i.InfluxdbDataExceptionTranslator] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-7] java.lang.ClassCastException: class org.msgpack.value.impl.ImmutableLongValueImpl cannot be cast to class org.msgpack.value.ImmutableMapValue (org.msgpack.value.impl.ImmutableLongValueImpl and org.msgpack.value.ImmutableMapValue are in unnamed module of loader org.apache.catalina.loader.ParallelWebappClassLoader @24e8de5c)
2024-03-04 11:11:09.312+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-7] [2,006] Unknown error occurred. Contact the administrator if this re-occurs.
2024-03-04 11:11:09.313+0000 [L: ERROR] [O: E.c.t.p.i.InfluxdbDataExceptionTranslator] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-4] java.lang.ClassCastException: class org.msgpack.value.impl.ImmutableLongValueImpl cannot be cast to class org.msgpack.value.ImmutableMapValue (org.msgpack.value.impl.ImmutableLongValueImpl and org.msgpack.value.ImmutableMapValue are in unnamed module of loader org.apache.catalina.loader.ParallelWebappClassLoader @24e8de5c)
2024-03-04 11:11:09.320+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-4] [2,006] Unknown error occurred. Contact the administrator if this re-occurs.
2024-03-04 11:11:09.321+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-7] Execution error in service script [getCustomKibbleData] :: com.thingworx.common.exceptions.DataAccessException: [2,006] Unknown error occurred. Contact the administrator if this re-occurs.
2024-03-04 11:11:09.324+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-4] Execution error in service script [getCustomKibbleData] :: com.thingworx.common.exceptions.DataAccessException: [2,006] Unknown error occurred. Contact the administrator if this re-occurs.
2024-03-04 11:11:09.541+0000 [L: ERROR] [O: E.c.t.p.i.InfluxdbDataExceptionTranslator] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-10] java.lang.ClassCastException: class org.msgpack.value.impl.ImmutableLongValueImpl cannot be cast to class org.msgpack.value.ImmutableMapValue (org.msgpack.value.impl.ImmutableLongValueImpl and org.msgpack.value.ImmutableMapValue are in unnamed module of loader org.apache.catalina.loader.ParallelWebappClassLoader @24e8de5c)
2024-03-04 11:11:09.541+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-10] [2,006] Unknown error occurred. Contact the administrator if this re-occurs.
2024-03-04 11:11:09.543+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-10] Execution error in service script [getVoltageTHDData] :: com.thingworx.common.exceptions.DataAccessException: [2,006] Unknown error occurred. Contact the administrator if this re-occurs.
2024-03-04 11:11:09.550+0000 [L: ERROR] [O: E.c.t.p.i.InfluxdbDataExceptionTranslator] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-6] java.lang.ClassCastException: class org.msgpack.value.impl.ImmutableLongValueImpl cannot be cast to class org.msgpack.value.ImmutableMapValue (org.msgpack.value.impl.ImmutableLongValueImpl and org.msgpack.value.ImmutableMapValue are in unnamed module of loader org.apache.catalina.loader.ParallelWebappClassLoader @24e8de5c)
2024-03-04 11:11:09.550+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-6] [2,006] Unknown error occurred. Contact the administrator if this re-occurs.
2024-03-04 11:11:09.555+0000 [L: ERROR] [O: E.c.t.p.i.InfluxdbDataExceptionTranslator] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-9] java.lang.ClassCastException: class org.msgpack.value.impl.ImmutableLongValueImpl cannot be cast to class org.msgpack.value.ImmutableMapValue (org.msgpack.value.impl.ImmutableLongValueImpl and org.msgpack.value.ImmutableMapValue are in unnamed module of loader org.apache.catalina.loader.ParallelWebappClassLoader @24e8de5c)
2024-03-04 11:11:09.555+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-9] [2,006] Unknown error occurred. Contact the administrator if this re-occurs.
2024-03-04 11:11:09.558+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-9] Execution error in service script [getLineVoltageData] :: com.thingworx.common.exceptions.DataAccessException: [2,006] Unknown error occurred. Contact the administrator if this re-occurs.
2024-03-04 11:11:13.895+0000 [L: ERROR] [O: E.c.t.p.i.InfluxdbDataExceptionTranslator] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-7] java.lang.ClassCastException: class org.msgpack.value.impl.ImmutableLongValueImpl cannot be cast to class org.msgpack.value.ImmutableMapValue (org.msgpack.value.impl.ImmutableLongValueImpl and org.msgpack.value.ImmutableMapValue are in unnamed module of loader org.apache.catalina.loader.ParallelWebappClassLoader @24e8de5c)
2024-03-04 11:11:13.896+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-7] [2,006] Unknown error occurred. Contact the administrator if this re-occurs.
2024-03-04 11:11:13.899+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-7] Execution error in service script [getCustomKibbleData] :: com.thingworx.common.exceptions.DataAccessException: [2,006] Unknown error occurred. Contact the administrator if this re-occurs.
2024-03-04 11:12:34.462+0000 [L: ERROR] [O: E.c.t.p.i.InfluxdbDataExceptionTranslator] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-1] java.lang.ClassCastException: class org.msgpack.value.impl.ImmutableLongValueImpl cannot be cast to class org.msgpack.value.ImmutableMapValue (org.msgpack.value.impl.ImmutableLongValueImpl and org.msgpack.value.ImmutableMapValue are in unnamed module of loader org.apache.catalina.loader.ParallelWebappClassLoader @24e8de5c)
2024-03-04 11:12:34.462+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-1] [2,006] Unknown error occurred. Contact the administrator if this re-occurs.
2024-03-04 11:12:34.464+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-1] Unable to Invoke Service QueryPropertyHistory on PowerSupply_Thing4 : com.thingworx.common.exceptions.DataAccessException: [2,006] Unknown error occurred. Contact the administrator if this re-occurs.
2024-03-04 11:12:56.308+0000 [L: ERROR] [O: E.c.t.p.i.InfluxdbDataExceptionTranslator] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-9] java.lang.ClassCastException: class org.msgpack.value.impl.ImmutableLongValueImpl cannot be cast to class org.msgpack.value.ImmutableMapValue (org.msgpack.value.impl.ImmutableLongValueImpl and org.msgpack.value.ImmutableMapValue are in unnamed module of loader org.apache.catalina.loader.ParallelWebappClassLoader @24e8de5c)
2024-03-04 11:12:56.308+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-9] [2,006] Unknown error occurred. Contact the administrator if this re-occurs.
2024-03-04 11:12:56.310+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-9] Unable to Invoke Service QueryNamedPropertyHistory on PowerSupply_Thing4 : com.thingworx.common.exceptions.DataAccessException: [2,006] Unknown error occurred. Contact the administrator if this re-occurs.
2024-03-04 11:13:14.359+0000 [L: ERROR] [O: E.c.t.p.i.InfluxdbDataExceptionTranslator] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-7] java.lang.ClassCastException: class org.msgpack.value.impl.ImmutableLongValueImpl cannot be cast to class org.msgpack.value.ImmutableMapValue (org.msgpack.value.impl.ImmutableLongValueImpl and org.msgpack.value.ImmutableMapValue are in unnamed module of loader org.apache.catalina.loader.ParallelWebappClassLoader @24e8de5c)
2024-03-04 11:13:14.360+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-7] [2,006] Unknown error occurred. Contact the administrator if this re-occurs.
2024-03-04 11:13:14.362+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-7] Unable to Invoke Service QueryNamedPropertyHistory on PowerSupply_Thing4 : com.thingworx.common.exceptions.DataAccessException: [2,006] Unknown error occurred. Contact the administrator if this re-occurs.
2024-03-04 11:13:15.650+0000 [L: ERROR] [O: E.c.t.p.i.InfluxdbDataExceptionTranslator] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-8] java.lang.ClassCastException: class org.msgpack.value.impl.ImmutableLongValueImpl cannot be cast to class org.msgpack.value.ImmutableMapValue (org.msgpack.value.impl.ImmutableLongValueImpl and org.msgpack.value.ImmutableMapValue are in unnamed module of loader org.apache.catalina.loader.ParallelWebappClassLoader @24e8de5c)
2024-03-04 11:13:15.650+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-8] [2,006] Unknown error occurred. Contact the administrator if this re-occurs.
2024-03-04 11:13:15.651+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-8] Unable to Invoke Service QueryNamedPropertyHistory on PowerSupply_Thing4 : com.thingworx.common.exceptions.DataAccessException: [2,006] Unknown error occurred. Contact the administrator if this re-occurs.
2024-03-04 11:13:26.852+0000 [L: ERROR] [O: E.c.t.p.i.InfluxdbDataExceptionTranslator] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-5] java.lang.ClassCastException: class org.msgpack.value.impl.ImmutableLongValueImpl cannot be cast to class org.msgpack.value.ImmutableMapValue (org.msgpack.value.impl.ImmutableLongValueImpl and org.msgpack.value.ImmutableMapValue are in unnamed module of loader org.apache.catalina.loader.ParallelWebappClassLoader @24e8de5c)
2024-03-04 11:13:26.853+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-5] [2,006] Unknown error occurred. Contact the administrator if this re-occurs.
2024-03-04 11:13:26.854+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-5] Unable to Invoke Service QueryNamedPropertyHistory on PowerSupply_Thing4 : com.thingworx.common.exceptions.DataAccessException: [2,006] Unknown error occurred. Contact the administrator if this re-occurs.
2024-03-04 11:16:02.875+0000 [L: ERROR] [O: E.c.t.p.i.InfluxdbDataExceptionTranslator] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-7] java.lang.ClassCastException: class org.msgpack.value.impl.ImmutableLongValueImpl cannot be cast to class org.msgpack.value.ImmutableMapValue (org.msgpack.value.impl.ImmutableLongValueImpl and org.msgpack.value.ImmutableMapValue are in unnamed module of loader org.apache.catalina.loader.ParallelWebappClassLoader @24e8de5c)
2024-03-04 11:16:02.875+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-7] [2,006] Unknown error occurred. Contact the administrator if this re-occurs.
2024-03-04 11:16:02.878+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-7] Unable to Invoke Service QueryNamedPropertyHistory on PowerSupply_Thing4 : com.thingworx.common.exceptions.DataAccessException: [2,006] Unknown error occurred. Contact the administrator if this re-occurs.
2024-03-04 11:31:12.008+0000 [L: ERROR] [O: E.c.t.p.i.InfluxdbDataExceptionTranslator] [I: ] [U: SuperUser] [S: ] [P: ] [T: pool-9-thread-3] java.lang.ClassCastException: class org.msgpack.value.impl.ImmutableLongValueImpl cannot be cast to class org.msgpack.value.ImmutableMapValue (org.msgpack.value.impl.ImmutableLongValueImpl and org.msgpack.value.ImmutableMapValue are in unnamed module of loader org.apache.catalina.loader.ParallelWebappClassLoader @24e8de5c)
2024-03-04 11:31:12.009+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: SuperUser] [S: ] [P: ] [T: pool-9-thread-3] [2,006] Unknown error occurred. Contact the administrator if this re-occurs.
2024-03-04 11:31:12.009+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: SuperUser] [S: ] [P: ] [T: pool-9-thread-3] Unable to write entry in stream [TestWeather_VS] [com.thingworx.common.exceptions.DataAccessException: [2,006] Unknown error occurred. Contact the administrator if this re-occurs.]
2024-03-04 11:31:12.801+0000 [L: ERROR] [O: E.c.t.p.i.InfluxdbDataExceptionTranslator] [I: ] [U: SuperUser] [S: ] [P: ] [T: pool-9-thread-2] java.lang.ClassCastException: class org.msgpack.value.impl.ImmutableLongValueImpl cannot be cast to class org.msgpack.value.ImmutableMapValue (org.msgpack.value.impl.ImmutableLongValueImpl and org.msgpack.value.ImmutableMapValue are in unnamed module of loader org.apache.catalina.loader.ParallelWebappClassLoader @24e8de5c)
2024-03-04 11:31:12.801+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: SuperUser] [S: ] [P: ] [T: pool-9-thread-2] [2,006] Unknown error occurred. Contact the administrator if this re-occurs.
2024-03-04 11:31:12.801+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: SuperUser] [S: ] [P: ] [T: pool-9-thread-2] Unable to write entry in stream [TestWeather_VS] [com.thingworx.common.exceptions.DataAccessException: [2,006] Unknown error occurred. Contact the administrator if this re-occurs.]
2024-03-04 11:34:22.247+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-4] Unable to process import: unauthorized access
2024-03-04 11:34:22.289+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-4] Import Failed: unauthorized access
2024-03-04 11:35:34.339+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-7] Unable to process import: unauthorized access
2024-03-04 11:35:34.341+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-7] Import Failed: unauthorized access
2024-03-04 11:36:47.791+0000 [L: ERROR] [O: E.c.t.p.i.InfluxdbDataExceptionTranslator] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-4] java.lang.ClassCastException: class org.msgpack.value.impl.ImmutableLongValueImpl cannot be cast to class org.msgpack.value.ImmutableMapValue (org.msgpack.value.impl.ImmutableLongValueImpl and org.msgpack.value.ImmutableMapValue are in unnamed module of loader org.apache.catalina.loader.ParallelWebappClassLoader @24e8de5c)
2024-03-04 11:36:47.792+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-4] [2,006] Unknown error occurred. Contact the administrator if this re-occurs.
2024-03-04 11:36:47.794+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-4] Unable to Invoke Service QueryPropertyHistory on PowerSupply_Thing4 : com.thingworx.common.exceptions.DataAccessException: [2,006] Unknown error occurred. Contact the administrator if this re-occurs.
2024-03-04 11:37:47.110+0000 [L: ERROR] [O: E.c.t.p.i.Influxdb2DataExceptionTranslator] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-8] timeout
2024-03-04 11:37:47.111+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-8] [2,006] Unknown error occurred. Contact the administrator if this re-occurs.
2024-03-04 11:37:47.121+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-8] Unable to Invoke Service QueryNamedPropertyHistory on PowerSupply_Thing4 : com.thingworx.common.exceptions.DataAccessException: [2,006] Unknown error occurred. Contact the administrator if this re-occurs.
2024-03-04 11:38:04.536+0000 [L: ERROR] [O: E.c.t.p.i.Influxdb2DataExceptionTranslator] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-6] timeout
2024-03-04 11:38:04.536+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-6] [2,006] Unknown error occurred. Contact the administrator if this re-occurs.
2024-03-04 11:38:04.538+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-6] Unable to Invoke Service QueryNamedPropertyHistory on PowerSupply_Thing4 : com.thingworx.common.exceptions.DataAccessException: [2,006] Unknown error occurred. Contact the administrator if this re-occurs.
2024-03-04 11:40:22.605+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: SuperUser] [S: ] [P: ] [T: ForkJoinPool-1-worker-21] java.lang.ClassCastException: class org.msgpack.value.impl.ImmutableLongValueImpl cannot be cast to class org.msgpack.value.ImmutableMapValue (org.msgpack.value.impl.ImmutableLongValueImpl and org.msgpack.value.ImmutableMapValue are in unnamed module of loader org.apache.catalina.loader.ParallelWebappClassLoader @39ce27f2)
2024-03-04 11:40:22.608+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: SuperUser] [S: ] [P: ] [T: ForkJoinPool-1-worker-21] Unable To Initialize Entity InfluxDB in PersistenceProviders: java.lang.ClassCastException: class org.msgpack.value.impl.ImmutableLongValueImpl cannot be cast to class org.msgpack.value.ImmutableMapValue (org.msgpack.value.impl.ImmutableLongValueImpl and org.msgpack.value.ImmutableMapValue are in unnamed module of loader org.apache.catalina.loader.ParallelWebappClassLoader @39ce27f2)
2024-03-04 11:40:24.119+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: MineWorx.Core.Machine_Template:ThingTemplate] [U: SuperUser] [S: ] [P: ] [T: ForkJoinPool-1-worker-21] Unable to create service handler for getEquipmentConnectivityStatus in MineWorx.Core.Machine_Template:ThingTemplate : Handler getEquipmentConnectivityStatus requires a ServiceDefinition
2024-03-04 11:48:43.731+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: ???] [S: ] [P: ] [T: https-jsse-nio-443-exec-6] Authentication failed: Please make sure the credentials are correct.
2024-03-04 11:48:59.419+0000 [L: ERROR] [O: E.c.t.p.i.InfluxdbDataExceptionTranslator] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-3] null
2024-03-04 11:48:59.419+0000 [L: ERROR] [O: E.c.t.p.i.InfluxdbDataExceptionTranslator] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-9] null
2024-03-04 11:48:59.419+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-3] [1,018] Data store unknown error: [Error occurred while accessing the data provider.]
2024-03-04 11:48:59.420+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-9] [1,018] Data store unknown error: [Error occurred while accessing the data provider.]
2024-03-04 11:48:59.428+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-9] Execution error in service script [ActionCam1] :: com.thingworx.common.exceptions.DataAccessException: [1,018] Data store unknown error: [Error occurred while accessing the data provider.]
2024-03-04 11:48:59.428+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-3] Execution error in service script [ActionCam1] :: com.thingworx.common.exceptions.DataAccessException: [1,018] Data store unknown error: [Error occurred while accessing the data provider.]
2024-03-04 11:48:59.514+0000 [L: ERROR] [O: E.c.t.p.i.InfluxdbDataExceptionTranslator] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-7] null
2024-03-04 11:48:59.514+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-7] [1,018] Data store unknown error: [Error occurred while accessing the data provider.]
2024-03-04 11:48:59.518+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-7] Execution error in service script [getKibbleShaftDepthData] :: com.thingworx.common.exceptions.DataAccessException: [1,018] Data store unknown error: [Error occurred while accessing the data provider.]
2024-03-04 11:49:00.110+0000 [L: ERROR] [O: E.c.t.p.i.InfluxdbDataExceptionTranslator] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-8] null
2024-03-04 11:49:00.110+0000 [L: ERROR] [O: E.c.t.p.i.InfluxdbDataExceptionTranslator] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-3] null
2024-03-04 11:49:00.111+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-3] [1,018] Data store unknown error: [Error occurred while accessing the data provider.]
2024-03-04 11:49:00.111+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-8] [1,018] Data store unknown error: [Error occurred while accessing the data provider.]
2024-03-04 11:49:00.119+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: snkosi] [S: ] [P: ] [T: https-jsse-nio-443-exec-3] Execution error in service script [getCustomKibbleData] :: com.thingworx.common.exceptions.DataAccessException: [1,018] Data store unknown error: [Error occurred while accessing the data provider.]
Application Log:
root@ubuntu:/ThingworxStorage/logs# tail -100 ApplicationLog.log
2024-03-04 12:40:54.252+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] ValueStreamProcessingSubsystem: QueryNamedPropertyHistory_callsPerSecond= 0, QueryNamedPropertyHistory_lastExecutionTime= 1061, QueryNamedPropertyHistory_lastRowCount= 1500, QueryPropertyHistory_callsPerSecond= 0, QueryPropertyHistory_lastExecutionTime= 0, QueryPropertyHistory_lastRowCount= 0, QueryNamedPropertyHistory_averageExecutionTime= [count= 10, min= 2.0E-5, max= 0.001554, mean= 8.13994434890331E-4, stddev= 6.386300738789276E-4, median= 0.001183, p75= 0.001323, p95= 0.001554, p98= 0.001554, p99= 0.001554, p999= 0.001554], QueryNamedPropertyHistory_averageRowCount= [count= 10, min= 0.0, max= 0.0015, mean= 9.125637260840213E-4, stddev= 7.321700860877063E-4, median= 0.0015, p75= 0.0015, p95= 0.0015, p98= 0.0015, p99= 0.0015, p999= 0.0015], QueryPropertyHistory_averageExecutionTime= [count= 0, min= 0.0, max= 0.0, mean= 0.0, stddev= 0.0, median= 0.0, p75= 0.0, p95= 0.0, p98= 0.0, p99= 0.0, p999= 0.0], QueryPropertyHistory_averageRowCount= [count= 0, min= 0.0, max= 0.0, mean= 0.0, stddev= 0.0, median= 0.0, p75= 0.0, p95= 0.0, p98= 0.0, p99= 0.0, p999= 0.0]
2024-03-04 12:40:54.252+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] WSCommunicationsSubsystem: BoundConnectedThings= 0, UnBoundConnectedThings= 0, activeWebsockets= 0
2024-03-04 12:40:54.252+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] InfluxDB2.StreamProcessing: maximumBlockSize= 2500, maximumQueueSize= 250000, maximumWaitTime= 10000, numberOfProcessingThreads= 5, queueSize= 0, scanRate= 5, sizeThreshold= 1000, totalBatchesFailed= 0, totalBatchesWritten= 0, totalWritesNotQueued= 0, totalWritesPerformed= 0, totalWritesQueued= 0
2024-03-04 12:40:54.252+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] InfluxDB2.ValueStreamProcessing: maximumBlockSize= 2500, maximumQueueSize= 500000, maximumWaitTime= 10000, numberOfProcessingThreads= 5, queueSize= 0, scanRate= 5, sizeThreshold= 1000, totalBatchesFailed= 0, totalBatchesWritten= 0, totalWritesNotQueued= 0, totalWritesPerformed= 0, totalWritesQueued= 0
2024-03-04 12:40:54.252+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] UserManagementSubsystem: activeSessions= 2, activeUsers= 2, userCount= 51, userSessions= 3
2024-03-04 12:40:54.252+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] TunnelSubsystem: activeTunnelCount= 0, totalTunnelCount= 0
2024-03-04 12:40:54.252+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] IntegrationSubsystem: IRConnectedInstanceCount= 0, numberOfConnectors= 1, requestCount= 0
2024-03-04 12:40:54.252+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] PlatformSubsystem: componentProjects= 4, solutionProjects= 0, thingCount= 288, eventQueueSize= 0.0, memoryInUse= 7.541435264E9, systemUpTime= 3631398, totalMemoryAllocated= 1.2582912E10, automaticProjectDependencyUpdates= 0, automaticProjectDependencyUpdatesByAddEntitiesOrSetEntitiesService= 0, manualProjectDependencyUpdates= 0
2024-03-04 12:40:54.252+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] MessageStoreSubsystem: activeThreads= 0, completedTaskCount= 0, corePoolSize= 10, curentPoolSize= 0, largestPoolSize= 0, maxPoolSize= 100, queueSize= 0, submitedTaskCount= 0
2024-03-04 12:40:54.252+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] EventProcessingSubsystem: activeThreads= 0, completedTaskCount= 3610, corePoolSize= 16, curentPoolSize= 16, largestPoolSize= 16, maxPoolSize= 500, queueSize= 0, submitedTaskCount= 3610
2024-03-04 12:40:54.252+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] ThingworxPersistenceProvider.PersistentPropertyProcessing: maximumBlockSize= 2500, maximumQueueSize= 100000, maximumWaitTime= 1000, numberOfProcessingThreads= 20, queueSize= 2, scanRate= 25, sizeThreshold= 1000, totalBatchesFailed= 0, totalBatchesWritten= 10236, totalWritesNotQueued= 0, totalWritesPerformed= 10932, totalWritesQueued= 10934
2024-03-04 12:40:54.252+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] ThingworxPersistenceProvider.ValueStreamProcessing: maximumBlockSize= 2500, maximumQueueSize= 500000, maximumWaitTime= 10000, numberOfProcessingThreads= 5, queueSize= 0, scanRate= 5, sizeThreshold= 1000, totalBatchesFailed= 0, totalBatchesWritten= 0, totalWritesNotQueued= 0, totalWritesPerformed= 0, totalWritesQueued= 0
2024-03-04 12:40:54.252+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] LicensingSubsystem: License usage stats for last month (CHECK_IN,CHECK_OUT)= 29 days (Feb 2024), ptc_navigate_contr= 0, ptc_navigate_contr_CHECK_IN= 0, ptc_navigate_contr_CHECK_OUT= 0, ptc_navigate_contr_DaysRemaining= 240, ptc_navigate_view= 0, ptc_navigate_view_CHECK_IN= 0, ptc_navigate_view_CHECK_OUT= 0, ptc_navigate_view_DaysRemaining= 240, ptc_navigate_view_adk_n= 0, ptc_navigate_view_adk_n_CHECK_IN= 0, ptc_navigate_view_adk_n_CHECK_OUT= 0, ptc_navigate_view_adk_n_DaysRemaining= 240, ptc_solution_common= 0, ptc_solution_common_CHECK_IN= 0, ptc_solution_common_CHECK_OUT= 0, ptc_solution_common_DaysRemaining= 103, twx_asst_adv= 0, twx_asst_adv_CHECK_IN= 0, twx_asst_adv_CHECK_OUT= 0, twx_asst_adv_DaysRemaining= 240, twx_asst_adv_named= 0, twx_asst_adv_named_CHECK_IN= 0, twx_asst_adv_named_CHECK_OUT= 0, twx_asst_adv_named_DaysRemaining= 240, twx_cluster= 1, twx_cluster_CHECK_IN= 0, twx_cluster_CHECK_OUT= 0, twx_composer= 1, twx_composer_CHECK_IN= 0, twx_composer_CHECK_OUT= 128, twx_composer_DaysRemaining= 240, twx_mashup_builder= 167, twx_mashup_builder_CHECK_IN= 0, twx_mashup_builder_CHECK_OUT= 1, twx_mashup_builder_DaysRemaining= 240, twx_mfg_common= 0, twx_mfg_common_CHECK_IN= 0, twx_mfg_common_CHECK_OUT= 0, twx_mfg_common_DaysRemaining= 240, twx_mfg_common_named= 0, twx_mfg_common_named_CHECK_IN= 0, twx_mfg_common_named_CHECK_OUT= 0, twx_mfg_common_named_DaysRemaining= 240, twx_named_user= 49, twx_named_user_CHECK_IN= 0, twx_named_user_CHECK_OUT= 0, twx_named_user_DaysRemaining= 240, twx_prd_adv= 0, twx_prd_adv_CHECK_IN= 0, twx_prd_adv_CHECK_OUT= 0, twx_prd_adv_DaysRemaining= 240, twx_prd_adv_named= 0, twx_prd_adv_named_CHECK_IN= 0, twx_prd_adv_named_CHECK_OUT= 0, twx_prd_adv_named_DaysRemaining= 240, twx_telemetry_data_exception= 0, twx_telemetry_data_exception_CHECK_IN= 0, twx_telemetry_data_exception_CHECK_OUT= 0, twx_things= 151, twx_things_CHECK_IN= 6, twx_things_CHECK_OUT= 9, twx_things_DaysRemaining= 240, twx_utilities= 0, twx_utilities_CHECK_IN= 0, twx_utilities_CHECK_OUT= 0, twx_utilities_DaysRemaining= 240, twx_utilities_scm_packages= 0, twx_utilities_scm_packages_CHECK_IN= 0, twx_utilities_scm_packages_CHECK_OUT= 0, twx_utilities_scm_packages_DaysRemaining= 240, twx_utilities_workflows= 0, twx_utilities_workflows_CHECK_IN= 0, twx_utilities_workflows_CHECK_OUT= 0, twx_utilities_workflows_DaysRemaining= 240
2024-03-04 12:40:54.252+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] AuditSubsystem: AuditArchiveChunkSize= 50000.0, AuditArchiveDiskSpaceUsed= 0.0, AuditArchiveFilesCount= 0, AuditArchiveFreeDiskSpace= 606011.82, AuditOnlineRetentionTime= 60, OnlineAudits= 0, OnlineAuditsDirectPersistence= 0, AuditArchiveExecutionTime= 0, AuditCount= 0, audit.AuditCategory.Analytics= 0, audit.AuditCategory.Audit= 0, audit.AuditCategory.Authentication= 0, audit.AuditCategory.Collaboration= 0, audit.AuditCategory.DataManagement= 0, audit.AuditCategory.DataStorage= 0, audit.AuditCategory.DeviceCommunication= 0, audit.AuditCategory.FileTransfer= 0, audit.AuditCategory.ImportExport= 0, audit.AuditCategory.Lifecycle= 0, audit.AuditCategory.Modeling= 0, audit.AuditCategory.RemoteAccess= 0, audit.AuditCategory.SecurityConfiguration= 0, audit.AuditCategory.SoftwareManagement= 0, audit.AuditCategory.System= 0, audit.AuditCategory.ThingGroupMemberships= 0, audit.AuditCategory.Visualization= 0
2024-03-04 12:40:54.252+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] WSExecutionProcessingSubsystem: activeThreads= 0, completedTaskCount= 0, corePoolSize= 100, curentPoolSize= 0, largestPoolSize= 0, maxPoolSize= 1000, queueSize= 0, submitedTaskCount= 0
2024-03-04 12:40:54.252+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] FileTransferSubsystem: activeThreads= 0, completedTaskCount= 0, corePoolSize= 10, curentPoolSize= 0, largestPoolSize= 0, maxPoolSize= 10, queueSize= 0, submitedTaskCount= 0
2024-03-04 12:40:54.252+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] FederationSubsystem: clientCount= 1, publishedCount= 0, updateInterval= 100
2024-03-04 12:40:54.252+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] ThingworxPersistenceProvider.StreamProcessing: maximumBlockSize= 2500, maximumQueueSize= 250000, maximumWaitTime= 10000, numberOfProcessingThreads= 5, queueSize= 0, scanRate= 5, sizeThreshold= 1000, totalBatchesFailed= 0, totalBatchesWritten= 0, totalWritesNotQueued= 0, totalWritesPerformed= 0, totalWritesQueued= 0
2024-03-04 12:40:54.252+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] ThingworxPersistenceProvider.DataTableProcessing: maximumBlockSize= 2500, maximumQueueSize= 250000, maximumWaitTime= 10000, numberOfProcessingThreads= 5, queueSize= 0, scanRate= 5, sizeThreshold= 1, totalBatchesFailed= 0, totalBatchesWritten= 2, totalWritesNotQueued= 0, totalWritesPerformed= 2, totalWritesQueued= 2
2024-03-04 12:40:54.252+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] RelationshipSubsystem: GetWhereUsedCount= 0
2024-03-04 12:40:54.253+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] OrderedEventProcessingSubsystem: activeThreads= 0, blockedTaskCount= 0, completedTaskCount= 0, corePoolSize= 16, curentPoolSize= 0, largestPoolSize= 0, maxPoolSize= 500, queueSize= 0, rejectedTaskCount= 0, submitedTaskCount= 0
2024-03-04 12:40:54.253+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] ClusteringSubsystem: activeServers= 1, singletonServer= false, dynamicSubscriptionExecutionTime= [count= 0, mean_rate= 0.0, m1= 0.0, m5= 0.0, m15= 0.0, min= 0.0, max= 0.0, mean= 0.0, stddev= 0.0, median= 0.0, p75= 0.0, p95= 0.0, p98= 0.0, p99= 0.0, p999= 0.0], replayEphemeralExecutionTime= [count= 0, mean_rate= 0.0, m1= 0.0, m5= 0.0, m15= 0.0, min= 0.0, max= 0.0, mean= 0.0, stddev= 0.0, median= 0.0, p75= 0.0, p95= 0.0, p98= 0.0, p99= 0.0, p999= 0.0]
2024-03-04 12:40:54.253+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] ThingworxPersistenceProvider.ConnectionPool: BusyConnections= 0, IdleConnections= 5, MaxConnections= 100, ThreadsAwaitingCheckout= 0, TotalConnections= 5
2024-03-04 12:53:00.158+0000 [L: ERROR] [O: c.t.p.i.InfluxdbDataExceptionTranslator] [I: ] [U: Administrator] [S: ] [P: ] [T: TWEventProcessor-6] [1,018] Data store unknown error: [Error occurred while accessing the data provider.]
2024-03-04 12:53:00.161+0000 [L: ERROR] [O: c.t.s.s.e.EventInstance] [I: ] [U: Administrator] [S: ] [P: ] [T: TWEventProcessor-6] Error Executing Event Handler 'UpdateFaultReportStream' for event Type.Thing:Entity.FaultReportUpdate_Scheduler:Event.ScheduledEvent
2024-03-04 13:10:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] AlertProcessingSubsystem: anomalyAlertsInLastDay= 0, disabledAnomalyAlert= 0, enabledAnomalyAlert= 0, maximumQueueSize= 50000, queueSize= 55, thingWatcherResultService= 0, thingWatcherTrainingService= 0, thingsWithDisabledAnomalyAlert= 0, thingsWithEnabledAnomalyAlert= 0, totalAlertsQueued= 55
2024-03-04 13:10:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] ValueStreamProcessingSubsystem: QueryNamedPropertyHistory_callsPerSecond= 0, QueryNamedPropertyHistory_lastExecutionTime= 1061, QueryNamedPropertyHistory_lastRowCount= 1500, QueryPropertyHistory_callsPerSecond= 0, QueryPropertyHistory_lastExecutionTime= 0, QueryPropertyHistory_lastRowCount= 0, QueryNamedPropertyHistory_averageExecutionTime= [count= 10, min= 2.0E-5, max= 0.001554, mean= 8.13994434890331E-4, stddev= 6.386300738789276E-4, median= 0.001183, p75= 0.001323, p95= 0.001554, p98= 0.001554, p99= 0.001554, p999= 0.001554], QueryNamedPropertyHistory_averageRowCount= [count= 10, min= 0.0, max= 0.0015, mean= 9.125637260840213E-4, stddev= 7.321700860877063E-4, median= 0.0015, p75= 0.0015, p95= 0.0015, p98= 0.0015, p99= 0.0015, p999= 0.0015], QueryPropertyHistory_averageExecutionTime= [count= 0, min= 0.0, max= 0.0, mean= 0.0, stddev= 0.0, median= 0.0, p75= 0.0, p95= 0.0, p98= 0.0, p99= 0.0, p999= 0.0], QueryPropertyHistory_averageRowCount= [count= 0, min= 0.0, max= 0.0, mean= 0.0, stddev= 0.0, median= 0.0, p75= 0.0, p95= 0.0, p98= 0.0, p99= 0.0, p999= 0.0]
2024-03-04 13:10:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] WSCommunicationsSubsystem: BoundConnectedThings= 0, UnBoundConnectedThings= 0, activeWebsockets= 0
2024-03-04 13:10:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] InfluxDB2.StreamProcessing: maximumBlockSize= 2500, maximumQueueSize= 250000, maximumWaitTime= 10000, numberOfProcessingThreads= 5, queueSize= 0, scanRate= 5, sizeThreshold= 1000, totalBatchesFailed= 0, totalBatchesWritten= 0, totalWritesNotQueued= 0, totalWritesPerformed= 0, totalWritesQueued= 0
2024-03-04 13:10:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] InfluxDB2.ValueStreamProcessing: maximumBlockSize= 2500, maximumQueueSize= 500000, maximumWaitTime= 10000, numberOfProcessingThreads= 5, queueSize= 0, scanRate= 5, sizeThreshold= 1000, totalBatchesFailed= 0, totalBatchesWritten= 0, totalWritesNotQueued= 0, totalWritesPerformed= 0, totalWritesQueued= 0
2024-03-04 13:10:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] UserManagementSubsystem: activeSessions= 2, activeUsers= 2, userCount= 51, userSessions= 3
2024-03-04 13:10:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] TunnelSubsystem: activeTunnelCount= 0, totalTunnelCount= 0
2024-03-04 13:10:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] IntegrationSubsystem: IRConnectedInstanceCount= 0, numberOfConnectors= 1, requestCount= 0
2024-03-04 13:10:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] PlatformSubsystem: componentProjects= 4, solutionProjects= 0, thingCount= 288, eventQueueSize= 0.0, memoryInUse= 2.151624264E9, systemUpTime= 5431397, totalMemoryAllocated= 1.2582912E10, automaticProjectDependencyUpdates= 0, automaticProjectDependencyUpdatesByAddEntitiesOrSetEntitiesService= 0, manualProjectDependencyUpdates= 0
2024-03-04 13:10:54.235+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] MessageStoreSubsystem: activeThreads= 0, completedTaskCount= 0, corePoolSize= 10, curentPoolSize= 0, largestPoolSize= 0, maxPoolSize= 100, queueSize= 0, submitedTaskCount= 0
2024-03-04 13:10:54.235+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] EventProcessingSubsystem: activeThreads= 0, completedTaskCount= 5414, corePoolSize= 16, curentPoolSize= 16, largestPoolSize= 16, maxPoolSize= 500, queueSize= 0, submitedTaskCount= 5414
2024-03-04 13:10:54.235+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] ThingworxPersistenceProvider.PersistentPropertyProcessing: maximumBlockSize= 2500, maximumQueueSize= 100000, maximumWaitTime= 1000, numberOfProcessingThreads= 20, queueSize= 3, scanRate= 25, sizeThreshold= 1000, totalBatchesFailed= 0, totalBatchesWritten= 15559, totalWritesNotQueued= 0, totalWritesPerformed= 16332, totalWritesQueued= 16335
2024-03-04 13:10:54.235+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] ThingworxPersistenceProvider.ValueStreamProcessing: maximumBlockSize= 2500, maximumQueueSize= 500000, maximumWaitTime= 10000, numberOfProcessingThreads= 5, queueSize= 0, scanRate= 5, sizeThreshold= 1000, totalBatchesFailed= 0, totalBatchesWritten= 0, totalWritesNotQueued= 0, totalWritesPerformed= 0, totalWritesQueued= 0
2024-03-04 13:10:54.235+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] LicensingSubsystem: License usage stats for last month (CHECK_IN,CHECK_OUT)= 29 days (Feb 2024), ptc_navigate_contr= 0, ptc_navigate_contr_CHECK_IN= 0, ptc_navigate_contr_CHECK_OUT= 0, ptc_navigate_contr_DaysRemaining= 240, ptc_navigate_view= 0, ptc_navigate_view_CHECK_IN= 0, ptc_navigate_view_CHECK_OUT= 0, ptc_navigate_view_DaysRemaining= 240, ptc_navigate_view_adk_n= 0, ptc_navigate_view_adk_n_CHECK_IN= 0, ptc_navigate_view_adk_n_CHECK_OUT= 0, ptc_navigate_view_adk_n_DaysRemaining= 240, ptc_solution_common= 0, ptc_solution_common_CHECK_IN= 0, ptc_solution_common_CHECK_OUT= 0, ptc_solution_common_DaysRemaining= 103, twx_asst_adv= 0, twx_asst_adv_CHECK_IN= 0, twx_asst_adv_CHECK_OUT= 0, twx_asst_adv_DaysRemaining= 240, twx_asst_adv_named= 0, twx_asst_adv_named_CHECK_IN= 0, twx_asst_adv_named_CHECK_OUT= 0, twx_asst_adv_named_DaysRemaining= 240, twx_cluster= 1, twx_cluster_CHECK_IN= 0, twx_cluster_CHECK_OUT= 0, twx_composer= 1, twx_composer_CHECK_IN= 0, twx_composer_CHECK_OUT= 128, twx_composer_DaysRemaining= 240, twx_mashup_builder= 167, twx_mashup_builder_CHECK_IN= 0, twx_mashup_builder_CHECK_OUT= 1, twx_mashup_builder_DaysRemaining= 240, twx_mfg_common= 0, twx_mfg_common_CHECK_IN= 0, twx_mfg_common_CHECK_OUT= 0, twx_mfg_common_DaysRemaining= 240, twx_mfg_common_named= 0, twx_mfg_common_named_CHECK_IN= 0, twx_mfg_common_named_CHECK_OUT= 0, twx_mfg_common_named_DaysRemaining= 240, twx_named_user= 49, twx_named_user_CHECK_IN= 0, twx_named_user_CHECK_OUT= 0, twx_named_user_DaysRemaining= 240, twx_prd_adv= 0, twx_prd_adv_CHECK_IN= 0, twx_prd_adv_CHECK_OUT= 0, twx_prd_adv_DaysRemaining= 240, twx_prd_adv_named= 0, twx_prd_adv_named_CHECK_IN= 0, twx_prd_adv_named_CHECK_OUT= 0, twx_prd_adv_named_DaysRemaining= 240, twx_telemetry_data_exception= 0, twx_telemetry_data_exception_CHECK_IN= 0, twx_telemetry_data_exception_CHECK_OUT= 0, twx_things= 151, twx_things_CHECK_IN= 6, twx_things_CHECK_OUT= 9, twx_things_DaysRemaining= 240, twx_utilities= 0, twx_utilities_CHECK_IN= 0, twx_utilities_CHECK_OUT= 0, twx_utilities_DaysRemaining= 240, twx_utilities_scm_packages= 0, twx_utilities_scm_packages_CHECK_IN= 0, twx_utilities_scm_packages_CHECK_OUT= 0, twx_utilities_scm_packages_DaysRemaining= 240, twx_utilities_workflows= 0, twx_utilities_workflows_CHECK_IN= 0, twx_utilities_workflows_CHECK_OUT= 0, twx_utilities_workflows_DaysRemaining= 240
2024-03-04 13:10:54.235+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] AuditSubsystem: AuditArchiveChunkSize= 50000.0, AuditArchiveDiskSpaceUsed= 0.0, AuditArchiveFilesCount= 0, AuditArchiveFreeDiskSpace= 615563.38, AuditOnlineRetentionTime= 60, OnlineAudits= 0, OnlineAuditsDirectPersistence= 0, AuditArchiveExecutionTime= 0, AuditCount= 0, audit.AuditCategory.Analytics= 0, audit.AuditCategory.Audit= 0, audit.AuditCategory.Authentication= 0, audit.AuditCategory.Collaboration= 0, audit.AuditCategory.DataManagement= 0, audit.AuditCategory.DataStorage= 0, audit.AuditCategory.DeviceCommunication= 0, audit.AuditCategory.FileTransfer= 0, audit.AuditCategory.ImportExport= 0, audit.AuditCategory.Lifecycle= 0, audit.AuditCategory.Modeling= 0, audit.AuditCategory.RemoteAccess= 0, audit.AuditCategory.SecurityConfiguration= 0, audit.AuditCategory.SoftwareManagement= 0, audit.AuditCategory.System= 0, audit.AuditCategory.ThingGroupMemberships= 0, audit.AuditCategory.Visualization= 0
2024-03-04 13:10:54.235+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] WSExecutionProcessingSubsystem: activeThreads= 0, completedTaskCount= 0, corePoolSize= 100, curentPoolSize= 0, largestPoolSize= 0, maxPoolSize= 1000, queueSize= 0, submitedTaskCount= 0
2024-03-04 13:10:54.235+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] FileTransferSubsystem: activeThreads= 0, completedTaskCount= 0, corePoolSize= 10, curentPoolSize= 0, largestPoolSize= 0, maxPoolSize= 10, queueSize= 0, submitedTaskCount= 0
2024-03-04 13:10:54.235+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] FederationSubsystem: clientCount= 1, publishedCount= 0, updateInterval= 100
2024-03-04 13:10:54.235+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] ThingworxPersistenceProvider.StreamProcessing: maximumBlockSize= 2500, maximumQueueSize= 250000, maximumWaitTime= 10000, numberOfProcessingThreads= 5, queueSize= 0, scanRate= 5, sizeThreshold= 1000, totalBatchesFailed= 0, totalBatchesWritten= 0, totalWritesNotQueued= 0, totalWritesPerformed= 0, totalWritesQueued= 0
2024-03-04 13:10:54.235+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] ThingworxPersistenceProvider.DataTableProcessing: maximumBlockSize= 2500, maximumQueueSize= 250000, maximumWaitTime= 10000, numberOfProcessingThreads= 5, queueSize= 0, scanRate= 5, sizeThreshold= 1, totalBatchesFailed= 0, totalBatchesWritten= 2, totalWritesNotQueued= 0, totalWritesPerformed= 2, totalWritesQueued= 2
2024-03-04 13:10:54.235+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] RelationshipSubsystem: GetWhereUsedCount= 0
2024-03-04 13:10:54.235+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] OrderedEventProcessingSubsystem: activeThreads= 0, blockedTaskCount= 0, completedTaskCount= 0, corePoolSize= 16, curentPoolSize= 0, largestPoolSize= 0, maxPoolSize= 500, queueSize= 0, rejectedTaskCount= 0, submitedTaskCount= 0
2024-03-04 13:10:54.235+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] ClusteringSubsystem: activeServers= 1, singletonServer= false, dynamicSubscriptionExecutionTime= [count= 0, mean_rate= 0.0, m1= 0.0, m5= 0.0, m15= 0.0, min= 0.0, max= 0.0, mean= 0.0, stddev= 0.0, median= 0.0, p75= 0.0, p95= 0.0, p98= 0.0, p99= 0.0, p999= 0.0], replayEphemeralExecutionTime= [count= 0, mean_rate= 0.0, m1= 0.0, m5= 0.0, m15= 0.0, min= 0.0, max= 0.0, mean= 0.0, stddev= 0.0, median= 0.0, p75= 0.0, p95= 0.0, p98= 0.0, p99= 0.0, p999= 0.0]
2024-03-04 13:10:54.235+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] ThingworxPersistenceProvider.ConnectionPool: BusyConnections= 0, IdleConnections= 5, MaxConnections= 100, ThreadsAwaitingCheckout= 0, TotalConnections= 5
2024-03-04 13:35:05.769+0000 [L: WARN] [O: c.t.w.c.HttpExecutionContext] [I: ] [U: ???] [S: ] [P: ] [T: https-jsse-nio-443-exec-6] Header value was null for header=accept-encoding
2024-03-04 13:40:05.825+0000 [L: WARN] [O: c.t.w.c.HttpExecutionContext] [I: ] [U: ???] [S: ] [P: ] [T: https-jsse-nio-443-exec-10] Header value was null for header=accept-encoding
2024-03-04 13:40:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] AlertProcessingSubsystem: anomalyAlertsInLastDay= 0, disabledAnomalyAlert= 0, enabledAnomalyAlert= 0, maximumQueueSize= 50000, queueSize= 55, thingWatcherResultService= 0, thingWatcherTrainingService= 0, thingsWithDisabledAnomalyAlert= 0, thingsWithEnabledAnomalyAlert= 0, totalAlertsQueued= 55
2024-03-04 13:40:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] ValueStreamProcessingSubsystem: QueryNamedPropertyHistory_callsPerSecond= 0, QueryNamedPropertyHistory_lastExecutionTime= 1061, QueryNamedPropertyHistory_lastRowCount= 1500, QueryPropertyHistory_callsPerSecond= 0, QueryPropertyHistory_lastExecutionTime= 0, QueryPropertyHistory_lastRowCount= 0, QueryNamedPropertyHistory_averageExecutionTime= [count= 10, min= 2.0E-5, max= 0.001554, mean= 8.13994434890331E-4, stddev= 6.386300738789276E-4, median= 0.001183, p75= 0.001323, p95= 0.001554, p98= 0.001554, p99= 0.001554, p999= 0.001554], QueryNamedPropertyHistory_averageRowCount= [count= 10, min= 0.0, max= 0.0015, mean= 9.125637260840213E-4, stddev= 7.321700860877063E-4, median= 0.0015, p75= 0.0015, p95= 0.0015, p98= 0.0015, p99= 0.0015, p999= 0.0015], QueryPropertyHistory_averageExecutionTime= [count= 0, min= 0.0, max= 0.0, mean= 0.0, stddev= 0.0, median= 0.0, p75= 0.0, p95= 0.0, p98= 0.0, p99= 0.0, p999= 0.0], QueryPropertyHistory_averageRowCount= [count= 0, min= 0.0, max= 0.0, mean= 0.0, stddev= 0.0, median= 0.0, p75= 0.0, p95= 0.0, p98= 0.0, p99= 0.0, p999= 0.0]
2024-03-04 13:40:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] WSCommunicationsSubsystem: BoundConnectedThings= 0, UnBoundConnectedThings= 0, activeWebsockets= 0
2024-03-04 13:40:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] InfluxDB2.StreamProcessing: maximumBlockSize= 2500, maximumQueueSize= 250000, maximumWaitTime= 10000, numberOfProcessingThreads= 5, queueSize= 0, scanRate= 5, sizeThreshold= 1000, totalBatchesFailed= 0, totalBatchesWritten= 0, totalWritesNotQueued= 0, totalWritesPerformed= 0, totalWritesQueued= 0
2024-03-04 13:40:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] InfluxDB2.ValueStreamProcessing: maximumBlockSize= 2500, maximumQueueSize= 500000, maximumWaitTime= 10000, numberOfProcessingThreads= 5, queueSize= 0, scanRate= 5, sizeThreshold= 1000, totalBatchesFailed= 0, totalBatchesWritten= 0, totalWritesNotQueued= 0, totalWritesPerformed= 0, totalWritesQueued= 0
2024-03-04 13:40:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] UserManagementSubsystem: activeSessions= 2, activeUsers= 2, userCount= 51, userSessions= 3
2024-03-04 13:40:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] TunnelSubsystem: activeTunnelCount= 0, totalTunnelCount= 0
2024-03-04 13:40:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] IntegrationSubsystem: IRConnectedInstanceCount= 0, numberOfConnectors= 1, requestCount= 0
2024-03-04 13:40:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] PlatformSubsystem: componentProjects= 4, solutionProjects= 0, thingCount= 288, eventQueueSize= 0.0, memoryInUse= 4.15125176E9, systemUpTime= 7231396, totalMemoryAllocated= 1.2582912E10, automaticProjectDependencyUpdates= 0, automaticProjectDependencyUpdatesByAddEntitiesOrSetEntitiesService= 0, manualProjectDependencyUpdates= 0
2024-03-04 13:40:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] MessageStoreSubsystem: activeThreads= 0, completedTaskCount= 0, corePoolSize= 10, curentPoolSize= 0, largestPoolSize= 0, maxPoolSize= 100, queueSize= 0, submitedTaskCount= 0
2024-03-04 13:40:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] EventProcessingSubsystem: activeThreads= 0, completedTaskCount= 7217, corePoolSize= 16, curentPoolSize= 16, largestPoolSize= 16, maxPoolSize= 500, queueSize= 0, submitedTaskCount= 7217
2024-03-04 13:40:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] ThingworxPersistenceProvider.PersistentPropertyProcessing: maximumBlockSize= 2500, maximumQueueSize= 100000, maximumWaitTime= 1000, numberOfProcessingThreads= 20, queueSize= 1, scanRate= 25, sizeThreshold= 1000, totalBatchesFailed= 0, totalBatchesWritten= 20885, totalWritesNotQueued= 0, totalWritesPerformed= 21739, totalWritesQueued= 21740
2024-03-04 13:40:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] ThingworxPersistenceProvider.ValueStreamProcessing: maximumBlockSize= 2500, maximumQueueSize= 500000, maximumWaitTime= 10000, numberOfProcessingThreads= 5, queueSize= 0, scanRate= 5, sizeThreshold= 1000, totalBatchesFailed= 0, totalBatchesWritten= 0, totalWritesNotQueued= 0, totalWritesPerformed= 0, totalWritesQueued= 0
2024-03-04 13:40:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] LicensingSubsystem: License usage stats for last month (CHECK_IN,CHECK_OUT)= 29 days (Feb 2024), ptc_navigate_contr= 0, ptc_navigate_contr_CHECK_IN= 0, ptc_navigate_contr_CHECK_OUT= 0, ptc_navigate_contr_DaysRemaining= 240, ptc_navigate_view= 0, ptc_navigate_view_CHECK_IN= 0, ptc_navigate_view_CHECK_OUT= 0, ptc_navigate_view_DaysRemaining= 240, ptc_navigate_view_adk_n= 0, ptc_navigate_view_adk_n_CHECK_IN= 0, ptc_navigate_view_adk_n_CHECK_OUT= 0, ptc_navigate_view_adk_n_DaysRemaining= 240, ptc_solution_common= 0, ptc_solution_common_CHECK_IN= 0, ptc_solution_common_CHECK_OUT= 0, ptc_solution_common_DaysRemaining= 103, twx_asst_adv= 0, twx_asst_adv_CHECK_IN= 0, twx_asst_adv_CHECK_OUT= 0, twx_asst_adv_DaysRemaining= 240, twx_asst_adv_named= 0, twx_asst_adv_named_CHECK_IN= 0, twx_asst_adv_named_CHECK_OUT= 0, twx_asst_adv_named_DaysRemaining= 240, twx_cluster= 1, twx_cluster_CHECK_IN= 0, twx_cluster_CHECK_OUT= 0, twx_composer= 1, twx_composer_CHECK_IN= 0, twx_composer_CHECK_OUT= 128, twx_composer_DaysRemaining= 240, twx_mashup_builder= 167, twx_mashup_builder_CHECK_IN= 0, twx_mashup_builder_CHECK_OUT= 1, twx_mashup_builder_DaysRemaining= 240, twx_mfg_common= 0, twx_mfg_common_CHECK_IN= 0, twx_mfg_common_CHECK_OUT= 0, twx_mfg_common_DaysRemaining= 240, twx_mfg_common_named= 0, twx_mfg_common_named_CHECK_IN= 0, twx_mfg_common_named_CHECK_OUT= 0, twx_mfg_common_named_DaysRemaining= 240, twx_named_user= 49, twx_named_user_CHECK_IN= 0, twx_named_user_CHECK_OUT= 0, twx_named_user_DaysRemaining= 240, twx_prd_adv= 0, twx_prd_adv_CHECK_IN= 0, twx_prd_adv_CHECK_OUT= 0, twx_prd_adv_DaysRemaining= 240, twx_prd_adv_named= 0, twx_prd_adv_named_CHECK_IN= 0, twx_prd_adv_named_CHECK_OUT= 0, twx_prd_adv_named_DaysRemaining= 240, twx_telemetry_data_exception= 0, twx_telemetry_data_exception_CHECK_IN= 0, twx_telemetry_data_exception_CHECK_OUT= 0, twx_things= 151, twx_things_CHECK_IN= 6, twx_things_CHECK_OUT= 9, twx_things_DaysRemaining= 240, twx_utilities= 0, twx_utilities_CHECK_IN= 0, twx_utilities_CHECK_OUT= 0, twx_utilities_DaysRemaining= 240, twx_utilities_scm_packages= 0, twx_utilities_scm_packages_CHECK_IN= 0, twx_utilities_scm_packages_CHECK_OUT= 0, twx_utilities_scm_packages_DaysRemaining= 240, twx_utilities_workflows= 0, twx_utilities_workflows_CHECK_IN= 0, twx_utilities_workflows_CHECK_OUT= 0, twx_utilities_workflows_DaysRemaining= 240
2024-03-04 13:40:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] AuditSubsystem: AuditArchiveChunkSize= 50000.0, AuditArchiveDiskSpaceUsed= 0.0, AuditArchiveFilesCount= 0, AuditArchiveFreeDiskSpace= 612415.94, AuditOnlineRetentionTime= 60, OnlineAudits= 0, OnlineAuditsDirectPersistence= 0, AuditArchiveExecutionTime= 0, AuditCount= 0, audit.AuditCategory.Analytics= 0, audit.AuditCategory.Audit= 0, audit.AuditCategory.Authentication= 0, audit.AuditCategory.Collaboration= 0, audit.AuditCategory.DataManagement= 0, audit.AuditCategory.DataStorage= 0, audit.AuditCategory.DeviceCommunication= 0, audit.AuditCategory.FileTransfer= 0, audit.AuditCategory.ImportExport= 0, audit.AuditCategory.Lifecycle= 0, audit.AuditCategory.Modeling= 0, audit.AuditCategory.RemoteAccess= 0, audit.AuditCategory.SecurityConfiguration= 0, audit.AuditCategory.SoftwareManagement= 0, audit.AuditCategory.System= 0, audit.AuditCategory.ThingGroupMemberships= 0, audit.AuditCategory.Visualization= 0
2024-03-04 13:40:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] WSExecutionProcessingSubsystem: activeThreads= 0, completedTaskCount= 0, corePoolSize= 100, curentPoolSize= 0, largestPoolSize= 0, maxPoolSize= 1000, queueSize= 0, submitedTaskCount= 0
2024-03-04 13:40:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] FileTransferSubsystem: activeThreads= 0, completedTaskCount= 0, corePoolSize= 10, curentPoolSize= 0, largestPoolSize= 0, maxPoolSize= 10, queueSize= 0, submitedTaskCount= 0
2024-03-04 13:40:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] FederationSubsystem: clientCount= 1, publishedCount= 0, updateInterval= 100
2024-03-04 13:40:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] ThingworxPersistenceProvider.StreamProcessing: maximumBlockSize= 2500, maximumQueueSize= 250000, maximumWaitTime= 10000, numberOfProcessingThreads= 5, queueSize= 0, scanRate= 5, sizeThreshold= 1000, totalBatchesFailed= 0, totalBatchesWritten= 0, totalWritesNotQueued= 0, totalWritesPerformed= 0, totalWritesQueued= 0
2024-03-04 13:40:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] ThingworxPersistenceProvider.DataTableProcessing: maximumBlockSize= 2500, maximumQueueSize= 250000, maximumWaitTime= 10000, numberOfProcessingThreads= 5, queueSize= 0, scanRate= 5, sizeThreshold= 1, totalBatchesFailed= 0, totalBatchesWritten= 2, totalWritesNotQueued= 0, totalWritesPerformed= 2, totalWritesQueued= 2
2024-03-04 13:40:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] RelationshipSubsystem: GetWhereUsedCount= 0
2024-03-04 13:40:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] OrderedEventProcessingSubsystem: activeThreads= 0, blockedTaskCount= 0, completedTaskCount= 0, corePoolSize= 16, curentPoolSize= 0, largestPoolSize= 0, maxPoolSize= 500, queueSize= 0, rejectedTaskCount= 0, submitedTaskCount= 0
2024-03-04 13:40:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] ClusteringSubsystem: activeServers= 1, singletonServer= false, dynamicSubscriptionExecutionTime= [count= 0, mean_rate= 0.0, m1= 0.0, m5= 0.0, m15= 0.0, min= 0.0, max= 0.0, mean= 0.0, stddev= 0.0, median= 0.0, p75= 0.0, p95= 0.0, p98= 0.0, p99= 0.0, p999= 0.0], replayEphemeralExecutionTime= [count= 0, mean_rate= 0.0, m1= 0.0, m5= 0.0, m15= 0.0, min= 0.0, max= 0.0, mean= 0.0, stddev= 0.0, median= 0.0, p75= 0.0, p95= 0.0, p98= 0.0, p99= 0.0, p999= 0.0]
2024-03-04 13:40:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] ThingworxPersistenceProvider.ConnectionPool: BusyConnections= 0, IdleConnections= 5, MaxConnections= 100, ThreadsAwaitingCheckout= 0, TotalConnections= 5
2024-03-04 14:10:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] AlertProcessingSubsystem: anomalyAlertsInLastDay= 0, disabledAnomalyAlert= 0, enabledAnomalyAlert= 0, maximumQueueSize= 50000, queueSize= 55, thingWatcherResultService= 0, thingWatcherTrainingService= 0, thingsWithDisabledAnomalyAlert= 0, thingsWithEnabledAnomalyAlert= 0, totalAlertsQueued= 55
2024-03-04 14:10:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] ValueStreamProcessingSubsystem: QueryNamedPropertyHistory_callsPerSecond= 0, QueryNamedPropertyHistory_lastExecutionTime= 1061, QueryNamedPropertyHistory_lastRowCount= 1500, QueryPropertyHistory_callsPerSecond= 0, QueryPropertyHistory_lastExecutionTime= 0, QueryPropertyHistory_lastRowCount= 0, QueryNamedPropertyHistory_averageExecutionTime= [count= 10, min= 2.0E-5, max= 0.001554, mean= 8.13994434890331E-4, stddev= 6.386300738789276E-4, median= 0.001183, p75= 0.001323, p95= 0.001554, p98= 0.001554, p99= 0.001554, p999= 0.001554], QueryNamedPropertyHistory_averageRowCount= [count= 10, min= 0.0, max= 0.0015, mean= 9.125637260840214E-4, stddev= 7.321700860877063E-4, median= 0.0015, p75= 0.0015, p95= 0.0015, p98= 0.0015, p99= 0.0015, p999= 0.0015], QueryPropertyHistory_averageExecutionTime= [count= 0, min= 0.0, max= 0.0, mean= 0.0, stddev= 0.0, median= 0.0, p75= 0.0, p95= 0.0, p98= 0.0, p99= 0.0, p999= 0.0], QueryPropertyHistory_averageRowCount= [count= 0, min= 0.0, max= 0.0, mean= 0.0, stddev= 0.0, median= 0.0, p75= 0.0, p95= 0.0, p98= 0.0, p99= 0.0, p999= 0.0]
2024-03-04 14:10:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] WSCommunicationsSubsystem: BoundConnectedThings= 0, UnBoundConnectedThings= 0, activeWebsockets= 0
2024-03-04 14:10:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] InfluxDB2.StreamProcessing: maximumBlockSize= 2500, maximumQueueSize= 250000, maximumWaitTime= 10000, numberOfProcessingThreads= 5, queueSize= 0, scanRate= 5, sizeThreshold= 1000, totalBatchesFailed= 0, totalBatchesWritten= 0, totalWritesNotQueued= 0, totalWritesPerformed= 0, totalWritesQueued= 0
2024-03-04 14:10:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] InfluxDB2.ValueStreamProcessing: maximumBlockSize= 2500, maximumQueueSize= 500000, maximumWaitTime= 10000, numberOfProcessingThreads= 5, queueSize= 0, scanRate= 5, sizeThreshold= 1000, totalBatchesFailed= 0, totalBatchesWritten= 0, totalWritesNotQueued= 0, totalWritesPerformed= 0, totalWritesQueued= 0
2024-03-04 14:10:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] UserManagementSubsystem: activeSessions= 1, activeUsers= 1, userCount= 51, userSessions= 3
2024-03-04 14:10:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] TunnelSubsystem: activeTunnelCount= 0, totalTunnelCount= 0
2024-03-04 14:10:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] IntegrationSubsystem: IRConnectedInstanceCount= 0, numberOfConnectors= 1, requestCount= 0
2024-03-04 14:10:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] PlatformSubsystem: componentProjects= 4, solutionProjects= 0, thingCount= 288, eventQueueSize= 0.0, memoryInUse= 6.12147484E9, systemUpTime= 9031396, totalMemoryAllocated= 1.2582912E10, automaticProjectDependencyUpdates= 0, automaticProjectDependencyUpdatesByAddEntitiesOrSetEntitiesService= 0, manualProjectDependencyUpdates= 0
2024-03-04 14:10:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] MessageStoreSubsystem: activeThreads= 0, completedTaskCount= 0, corePoolSize= 10, curentPoolSize= 0, largestPoolSize= 0, maxPoolSize= 100, queueSize= 0, submitedTaskCount= 0
2024-03-04 14:10:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] EventProcessingSubsystem: activeThreads= 0, completedTaskCount= 9020, corePoolSize= 16, curentPoolSize= 16, largestPoolSize= 16, maxPoolSize= 500, queueSize= 0, submitedTaskCount= 9020
2024-03-04 14:10:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] ThingworxPersistenceProvider.PersistentPropertyProcessing: maximumBlockSize= 2500, maximumQueueSize= 100000, maximumWaitTime= 1000, numberOfProcessingThreads= 20, queueSize= 1, scanRate= 25, sizeThreshold= 1000, totalBatchesFailed= 0, totalBatchesWritten= 26213, totalWritesNotQueued= 0, totalWritesPerformed= 27139, totalWritesQueued= 27140
2024-03-04 14:10:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] ThingworxPersistenceProvider.ValueStreamProcessing: maximumBlockSize= 2500, maximumQueueSize= 500000, maximumWaitTime= 10000, numberOfProcessingThreads= 5, queueSize= 0, scanRate= 5, sizeThreshold= 1000, totalBatchesFailed= 0, totalBatchesWritten= 0, totalWritesNotQueued= 0, totalWritesPerformed= 0, totalWritesQueued= 0
2024-03-04 14:10:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] LicensingSubsystem: License usage stats for last month (CHECK_IN,CHECK_OUT)= 29 days (Feb 2024), ptc_navigate_contr= 0, ptc_navigate_contr_CHECK_IN= 0, ptc_navigate_contr_CHECK_OUT= 0, ptc_navigate_contr_DaysRemaining= 240, ptc_navigate_view= 0, ptc_navigate_view_CHECK_IN= 0, ptc_navigate_view_CHECK_OUT= 0, ptc_navigate_view_DaysRemaining= 240, ptc_navigate_view_adk_n= 0, ptc_navigate_view_adk_n_CHECK_IN= 0, ptc_navigate_view_adk_n_CHECK_OUT= 0, ptc_navigate_view_adk_n_DaysRemaining= 240, ptc_solution_common= 0, ptc_solution_common_CHECK_IN= 0, ptc_solution_common_CHECK_OUT= 0, ptc_solution_common_DaysRemaining= 103, twx_asst_adv= 0, twx_asst_adv_CHECK_IN= 0, twx_asst_adv_CHECK_OUT= 0, twx_asst_adv_DaysRemaining= 240, twx_asst_adv_named= 0, twx_asst_adv_named_CHECK_IN= 0, twx_asst_adv_named_CHECK_OUT= 0, twx_asst_adv_named_DaysRemaining= 240, twx_cluster= 1, twx_cluster_CHECK_IN= 0, twx_cluster_CHECK_OUT= 0, twx_composer= 1, twx_composer_CHECK_IN= 0, twx_composer_CHECK_OUT= 128, twx_composer_DaysRemaining= 240, twx_mashup_builder= 167, twx_mashup_builder_CHECK_IN= 0, twx_mashup_builder_CHECK_OUT= 1, twx_mashup_builder_DaysRemaining= 240, twx_mfg_common= 0, twx_mfg_common_CHECK_IN= 0, twx_mfg_common_CHECK_OUT= 0, twx_mfg_common_DaysRemaining= 240, twx_mfg_common_named= 0, twx_mfg_common_named_CHECK_IN= 0, twx_mfg_common_named_CHECK_OUT= 0, twx_mfg_common_named_DaysRemaining= 240, twx_named_user= 49, twx_named_user_CHECK_IN= 0, twx_named_user_CHECK_OUT= 0, twx_named_user_DaysRemaining= 240, twx_prd_adv= 0, twx_prd_adv_CHECK_IN= 0, twx_prd_adv_CHECK_OUT= 0, twx_prd_adv_DaysRemaining= 240, twx_prd_adv_named= 0, twx_prd_adv_named_CHECK_IN= 0, twx_prd_adv_named_CHECK_OUT= 0, twx_prd_adv_named_DaysRemaining= 240, twx_telemetry_data_exception= 0, twx_telemetry_data_exception_CHECK_IN= 0, twx_telemetry_data_exception_CHECK_OUT= 0, twx_things= 151, twx_things_CHECK_IN= 6, twx_things_CHECK_OUT= 9, twx_things_DaysRemaining= 240, twx_utilities= 0, twx_utilities_CHECK_IN= 0, twx_utilities_CHECK_OUT= 0, twx_utilities_DaysRemaining= 240, twx_utilities_scm_packages= 0, twx_utilities_scm_packages_CHECK_IN= 0, twx_utilities_scm_packages_CHECK_OUT= 0, twx_utilities_scm_packages_DaysRemaining= 240, twx_utilities_workflows= 0, twx_utilities_workflows_CHECK_IN= 0, twx_utilities_workflows_CHECK_OUT= 0, twx_utilities_workflows_DaysRemaining= 240
2024-03-04 14:10:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] AuditSubsystem: AuditArchiveChunkSize= 50000.0, AuditArchiveDiskSpaceUsed= 0.0, AuditArchiveFilesCount= 0, AuditArchiveFreeDiskSpace= 612347.57, AuditOnlineRetentionTime= 60, OnlineAudits= 0, OnlineAuditsDirectPersistence= 0, AuditArchiveExecutionTime= 0, AuditCount= 0, audit.AuditCategory.Analytics= 0, audit.AuditCategory.Audit= 0, audit.AuditCategory.Authentication= 0, audit.AuditCategory.Collaboration= 0, audit.AuditCategory.DataManagement= 0, audit.AuditCategory.DataStorage= 0, audit.AuditCategory.DeviceCommunication= 0, audit.AuditCategory.FileTransfer= 0, audit.AuditCategory.ImportExport= 0, audit.AuditCategory.Lifecycle= 0, audit.AuditCategory.Modeling= 0, audit.AuditCategory.RemoteAccess= 0, audit.AuditCategory.SecurityConfiguration= 0, audit.AuditCategory.SoftwareManagement= 0, audit.AuditCategory.System= 0, audit.AuditCategory.ThingGroupMemberships= 0, audit.AuditCategory.Visualization= 0
2024-03-04 14:10:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] WSExecutionProcessingSubsystem: activeThreads= 0, completedTaskCount= 0, corePoolSize= 100, curentPoolSize= 0, largestPoolSize= 0, maxPoolSize= 1000, queueSize= 0, submitedTaskCount= 0
2024-03-04 14:10:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] FileTransferSubsystem: activeThreads= 0, completedTaskCount= 0, corePoolSize= 10, curentPoolSize= 0, largestPoolSize= 0, maxPoolSize= 10, queueSize= 0, submitedTaskCount= 0
2024-03-04 14:10:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] FederationSubsystem: clientCount= 1, publishedCount= 0, updateInterval= 100
2024-03-04 14:10:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] ThingworxPersistenceProvider.StreamProcessing: maximumBlockSize= 2500, maximumQueueSize= 250000, maximumWaitTime= 10000, numberOfProcessingThreads= 5, queueSize= 0, scanRate= 5, sizeThreshold= 1000, totalBatchesFailed= 0, totalBatchesWritten= 0, totalWritesNotQueued= 0, totalWritesPerformed= 0, totalWritesQueued= 0
2024-03-04 14:10:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] ThingworxPersistenceProvider.DataTableProcessing: maximumBlockSize= 2500, maximumQueueSize= 250000, maximumWaitTime= 10000, numberOfProcessingThreads= 5, queueSize= 0, scanRate= 5, sizeThreshold= 1, totalBatchesFailed= 0, totalBatchesWritten= 2, totalWritesNotQueued= 0, totalWritesPerformed= 2, totalWritesQueued= 2
2024-03-04 14:10:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] RelationshipSubsystem: GetWhereUsedCount= 0
2024-03-04 14:10:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] OrderedEventProcessingSubsystem: activeThreads= 0, blockedTaskCount= 0, completedTaskCount= 0, corePoolSize= 16, curentPoolSize= 0, largestPoolSize= 0, maxPoolSize= 500, queueSize= 0, rejectedTaskCount= 0, submitedTaskCount= 0
2024-03-04 14:10:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] ClusteringSubsystem: activeServers= 1, singletonServer= false, dynamicSubscriptionExecutionTime= [count= 0, mean_rate= 0.0, m1= 0.0, m5= 0.0, m15= 0.0, min= 0.0, max= 0.0, mean= 0.0, stddev= 0.0, median= 0.0, p75= 0.0, p95= 0.0, p98= 0.0, p99= 0.0, p999= 0.0], replayEphemeralExecutionTime= [count= 0, mean_rate= 0.0, m1= 0.0, m5= 0.0, m15= 0.0, min= 0.0, max= 0.0, mean= 0.0, stddev= 0.0, median= 0.0, p75= 0.0, p95= 0.0, p98= 0.0, p99= 0.0, p999= 0.0]
2024-03-04 14:10:54.234+0000 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: metrics-SystemMetricsLogReporter-1-thread-1] ThingworxPersistenceProvider.ConnectionPool: BusyConnections= 0, IdleConnections= 5, MaxConnections= 100, ThreadsAwaitingCheckout= 0, TotalConnections= 5
2024-03-04 14:15:05.926+0000 [L: WARN] [O: c.t.w.c.HttpExecutionContext] [I: ] [U: ???] [S: ] [P: ] [T: https-jsse-nio-443-exec-3] Header value was null for header=accept-encoding
Hi @NiKlaus  check the DB user permission, and look at the below article.
https://www.ptc.com/en/support/article/CS239982
