Use Input parameter to generate sql queries
SS_13175359
3-Newcomer
Hello
I am trying to figure out How to use input parameters for SQL in ThingWorx
Any help will be appreciated
Hello @SS_13175359
You can try and Use service input parameters to specify column value into WHERE clause of SQL Query or SQL Command by wrapping parameter name with double square brackets like [[xxx]]
for eg : SELECT * FROM user_data WHERE username = [[xxx]];
Let me know if it still doesn't work
Hi @SS_13175359. Look at the article below for your reference.
https://www.ptc.com/en/support/article/CS413368
Hello @SS_13175359
