Hello All,
I want to use only TLS 1.2 in my thingworx . Is there a way i can configure thingworx to restrict the specific TLS versions?
I will appreciate any help here
Hello @AM_10639709
As far as i can understand your use case It could be done by making changes in Server.xml. You can also refer following article for the same
Hello @AM_10639709
