Use table name as parameter for SQL command and SQL query
seanccc
How to use table name as parameter in Database thing for SQL command and query ?
I tried something like : select * from [[tableName]],  but it doesn't work.
Sean
1 ACCEPTED SOLUTION
Try this instead:  select * from <<tableName>>
seanccc
(To:nmilleson)
@nmilleson ,
Thank you for your quick reply.  I just found it as well and posted it before refreshing the page :  )
Sean
seanccc
(To:seanccc)
I found the answer in https://developer.thingworx.com/en/resources/guides/external-databases .
Just use <<tableName>> in SQL
Sean
