Workflow:
Is there any way I could get the "name" property without having to go through the Composer? If someone wants to view the mashup externally (direct link to mashup and logging in through the browser authentication popup) then the label is blank. Curious to know what options exist out there to get the "name" property to persist and work correctly.
Paul, this is a known internal issue, and we have devs working on it. This was primarily related to IE only though; the user extension properties worked fine on Firefox/ Chrome. What browser are you using?
I am currently experiencing this issue with Chome, Safari, FireFox on my mac machine. Can the current effort to resolve be updated to verify correct functionality in other browsers?
I'll go ahead and make a note of that on the internal ticket. On a side note, can you try using the ValueDisplay widget instead of Label widget? Does that make any difference on Firefox/ Chrome?
Unfortunately, using the Value Display widget did not aid in any way. I get the same result...
