Using Advanced Grid to delete a datatable row
  • March 20, 2020
  • 3147 views
I have a simple datatable thing that I am populating and editing successfully with the advanced grid. I am not able to get the widget to delete rows. The datatable does have a primary key. Can someone please tell me how to get this working? I am on v8.5 sp4, and I have seen other threads that say this was a bug that has been fixed in this version. ( cc @slangley )
I have tried binding
selected rows ->DeleteDataTableEntry
selected rows -> DeleteDataTableEntries
deleted table ->DeleteDataTableEntry
deleted table-> DeleteDataTableEntries
None of those seem to work.
Thanks in advance.
Best answer by slangley
Hi @jbaute.
Another internal case was opened for this issue.  The fix versions are 9.0, targeted for June, and 8.5.7, targeted for July.
For workarounds:
  1. Try adding the column name ID to get the delete functionality to work
  2. Use the DeleteDataTableEntryByKey service available in the datatable thing.  You'll need to add a button or some other mechanism for triggering the event.
Regards.
--Sharon
Support
March 20, 2020
Hi @jbaute.
This issue was addressed in ThingWorx 8.5.4.  Which version are you running?
Regards.
--Sharon
jbaute1-VisitorAuthor
@slangley
8.5.4-b222
Support
March 20, 2020
Hi @jbaute.
Can you please provide your recreation steps, mashup, and supporting entities?  We need to test it and validate, and possibly open a new case with R&D.
Regards.
--Sharon
