I have a simple datatable thing that I am populating and editing successfully with the advanced grid. I am not able to get the widget to delete rows. The datatable does have a primary key. Can someone please tell me how to get this working? I am on v8.5 sp4, and I have seen other threads that say this was a bug that has been fixed in this version. ( cc @slangley )
I have tried binding
selected rows ->DeleteDataTableEntry
selected rows -> DeleteDataTableEntries
deleted table ->DeleteDataTableEntry
deleted table-> DeleteDataTableEntries
None of those seem to work.
Thanks in advance.
Hi @jbaute.
Another internal case was opened for this issue. The fix versions are 9.0, targeted for June, and 8.5.7, targeted for July.
For workarounds:
--Sharon
Hi @jbaute.
This issue was addressed in ThingWorx 8.5.4. Which version are you running?
--Sharon
Hi @jbaute.
Can you please provide your recreation steps, mashup, and supporting entities? We need to test it and validate, and possibly open a new case with R&D.
--Sharon
Thanks @slangley
Attached is a simple test project. The mashup I'm using to test is the jmb_Activites2_mu
Hi @jbaute.
For workarounds:
--Sharon
Hi @jbaute.
ThingWorx 9.0 has just released. ThingWorx 8.5.7 is targeted for release on July 21.
--Sharon
Hi @jbaute.
ThingWorx 8.5.7 was recently released.
For the benefit of others on the community, please mark the appropriate response on this thread as the Accepted Solution.
--Sharon
