Using OPC Aggregator to connect to PLM Teamcenter
Sri1
I am planning to use OPC Aggregator in Thingworx to connect to PLM Teamcenter.
I wanted to explore the use of OPC Aggregator in Thingworx, how to make OPC connections.
Is there a manual that will be helpfull?
Thanks ,
Sri1
raluca_edu
(To:Sri1)
I found this article on the subject: https://www.ptc.com/en/support/article?n=CS302299
Hope it helps,
Raluca Edu
raluca_edu
(To:Sri1)
Hope it helps,
Raluca Edu
Sri1
(To:raluca_edu)
Hi Raluca Edu,
Thanks, i figured we can directly used Kepserver(since we are using this anyway) instead of OPC Aggregator.
Thanks and Regards,
Sri1
