how to view the image in the different(eg; png, jpg etc) format in the grid table.
You can use IMAGE, IMAGELINK or HTML base type in Grid Configuration.
What version of Thingworx are you using?
How are you storing your images? As media entities? In a repository?
I found plenty of support articles while searching on google.
But as I don't quite understand your use case, I won't link any here.
Jens
